Mowing BX2660 Mower Lift Arms Stuck Up
   / BX2660 Mower Lift Arms Stuck Up #11
I would check all linkage. Look behind the tire for the sliding bar and make sure its not bent or have a stick in it that would prevent the MMM arms from dropping. the pin should be able to move in that slot freely.
Thanks for all your help gentlemen,
I've got it fixed now. On each side of the frame is a welded flange that acts as a travel stop to limit how far the mower mount linkage can be retracted. It is designed so that the lower mower link arm sits against it and the upper link arm clears it. On my tractor, the upper link arm was hitting the stop on the passenger side and actually gouged a circular path in the metal. Somehow the stop got trapped between the upper and lower arms such that the linkage couldn't extend or retract. A little bit of "persuasion" got it unstuck and the mower mount immediately drooped to the 0 position. I then used an angle grinder to reduce the size of the stop just enough to let the upper arm clear it as the linkage moves.
I had thought I could just push the whole pivot mechanism towards the side that was sticking, but there wasn't enough play, so I went to the angle grinder. Y'all's very helpful advice helped me troubleshoot and I appreciate it.
Mike
   / BX2660 Mower Lift Arms Stuck Up #14
Now get that grass cut before the snow flies:thumbsup:
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
12 in Small Excavator Bucket (A52377)
12 in Small...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
UNUSED FUTURE FT-HJ6 HD STORAGE SHELVES (A51248)
UNUSED FUTURE...
