BX2660 transmission problem?
   / BX2660 transmission problem? #1
rick37160
I just moved from OK to TN and am currently building a new house on 5 acres. Going to this size of a "yard", I just bought my first tractor, a used BX2660 with a FEL and 60 MMM. It has 120 hours on it. I bought used because most of my money is going in the new house, plus the dealer was able to give me the remainder of the warranty.
Here's a problem I've noticed after using it the first time. After the tractor has been running about a half-hour to an hour it starts to stall and RPMs drop when going up a hill. It will slow to a crawl or, depending on the hill size, come to a stop. If I take my foot off the speed control pedal it will slowly increase in RPMs and then slowly start inching forward again. It seems to get worst the longer the tractor is running. All of this is with the throttle wide open. It got to the point where my wife on a Cub Cadet was out pacing me. Curious, I waited until the next morning and drove the tractor over the same hill. The tractor had only been running about 5 minutes and it handled the hills with no problems. My first thought was to check the fluids. The tractor was serviced by the dealer prior to us getting it and I致e checked all fluids. Transmission fluid was full and appeared to be fresh (clear).
This sounds to me like transmission problems. Prior to buying it, I called the previous owner and, of course, he said he had no problems with it. He said it was too small for the work he wanted to do, so he traded it in for a larger Kubota. My guess is this tractor WAS too small for the work he was doing and he screwed up the transmission. Before I contact the dealer is there anything I should look at. Being my first 鍍ractor? I want to make sure I知 not doing something wrong or overlooking something.
   / BX2660 transmission problem? #2
If your engine RPM's are dropping and nearly stalling , it's the engine
not the Transmission . A transmission problem wouldn't alter the diesel
performance. Check the fuel filters first . Could be a rate of flow problem.
Does the RPM just-fade or missfire ?
   / BX2660 transmission problem? #3
Agree with OrangeRidge, sounds more like it is not getting enough fuel. How long does it have to sit in order for it to run properly?
Since it is under warranty, rather than trying to fix it, I would get the dealer to make it right.
   / BX2660 transmission problem? #4
Agree with above.
Dump the fuel and see if that helps. Someone may have contaminated the diesel fuel with gasoline or water condensation. Since it sat at the dealer, for an unknown period of time, and if you can believe the previous owner, then I'd say it is a simply fuel issue. Filters are cheap and there is two of them.
While you're draining the fuel anyhow, I'd put new filters on it. They are simple, in-line fuel filters. Nothing special. Check the air filter compartment as well for mice building a nest or some such.
I always check the small stuff first before assuming major component failure.
   / BX2660 transmission problem? #5
Just change the fuel filter underneath the tractor. 90% chance it will fix the problem.
Thanks guys for the fast responses. I'll try replacing the fuel filters.
Wish I sent this message out before filling the tank this morning. :p
   / BX2660 transmission problem? #7
Don't drain it unless you have a reason. Fuel is too pricey! Probably just 120 hours worth of accumulated crud. The timing is about right for that first filter to clog. Make sure you clamp the fuel line with some vice grips or something before you pop that filter loose. It's gravity flow to that lower filter and you will get a bath if you don't! The little shiny thing IS NOT a filter!
   / BX2660 transmission problem? #8
yup filter first under tractor. :thumbsup:
   / BX2660 transmission problem? #9
Rick , when you've replaced the filter , break the old one open
with a hammer and post some photos of the contents . I'd like
to see what sort of condition a filter that can't pass a gallon
per hour looks like . Thanks .
   / BX2660 transmission problem? #10
Is it in high gear? My GC will do that if I forget and try to climb a steep hill in high.:ashamed:
   / BX2660 transmission problem? #12
Doesn't your hydro go to by-pass when travel speed can't
be maintained and there's no wheel spin on the GC ?
I am not sure, I have never stalled it, but have bogged it down. It kind of acts like the parking brake is on.
Tried it in both low & hight gear.
   / BX2660 transmission problem? #14
I have a BX2660 and it's doing the exact same thing. If you let if sit for 2-3 hours it works ok for another 30-45 minutes and then acts up again.
Please post if the filter(s) worked for you!
   / BX2660 transmission problem? #15
I can't find the thread, but another member had a kink in his fuel line and another trash in his tank.
   / BX2660 transmission problem? #16
Sounds like the filter is the problem, however if it continues i would also check to make sure the breather for the tank is not clogged the best way to check this would be to wait for it to act up then crack the fuel cap and see if it goes away. Also you may have debris that is plugging the inlet inside the tank. This would also explain why it isn't a constant problem.
   / BX2660 transmission problem? #17
I had the same issue, except my 2660 would have this happen while going downhill. After talking with someone I know that has worked with tractors his whole life I changed the fuel filters and problem solved. He said water can become trapped in the filter...water moves around just the right way when on a hill and engine starts to choke. *shrug* Don't know if that's true or not, but changing fuel filter fixed the issue.
   / BX2660 transmission problem? #18
I would also suggest that you dump some deisel conditioner into the tank. I had intermittant power issues on my G1900, and some deisel fuel conditioner/ cleaner addditive clear it up in one tank.
Note my G1900 had over 1000 hours at that point, so there is more chance that there was accumulation on the injectors, but it is a cheap PM. I put some in all my fuel since then.
Sorry for not posting sooner. Busy building a house.
It was a dirty fuel filter, first one.
Replaced both filters and drained a bit of the fuel and that did the trick.
Thanks guys.
2015 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2015 FREIGHTLINER...
2022 Ford F-450 Liftmoore 5000W Crane Service Truck (A59230)
2022 Ford F-450...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59905)
2005 INTERNATIONAL...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
John Deere S350 (A60462)
John Deere S350...
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
