Ballast BX2670 Tire ballast in warm climate
   / BX2670 Tire ballast in warm climate #1
cmugler
santa barbara, ca
kubota l2800
I am in southern california where it never freezes, do I need to add anything besides water to add ballast to tires and is it acceptable to do just the rear tires? Thanks BX2670
   / BX2670 Tire ballast in warm climate #2
Water is OK, but adding a gallon of antifreeze in each tire for the anti corrosive properties should go a long way to preventing rust on the inside of the rim.
   / BX2670 Tire ballast in warm climate #3
Growing up in AZ desert, we only ever loaded tractor tires with plain water.
   / BX2670 Tire ballast in warm climate #4
You can add water or any fluid. The difference is the lbs per gallon!
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
1274 (A50490)
1274 (A50490)
