BX2750 Snowblower bearing source
   / BX2750 Snowblower bearing source #11
Yeah but how many do you need to replace?
I wouldn't worry about buying new flanges unless they are mangled. I use hit mine w/ a wire brush and re-used them.
Edit: nevermind, I see you are looking to replace about 8 of them. Yeah that starts to add up.
   / BX2750 Snowblower bearing source #12
With selling multiple brands we often run across bearings that are the same bearing number being used between them. What we have found for differences is the application and when it was built. Applications that are current were the cheapest, the oldest was the most expensive!
We do not use the cheap bearings for any application and I've seen our normal prices lower then bearing outlet stores before depending on the applications.
   / BX2750 Snowblower bearing source #13
All you need is the shaft size which you've said is 1". Any bearing or farm supply store will have those in stock as they are a common bearing.
There are 3 separate part numbers for the 3 different bearing types - auger (2) and input shaft (2) bearings are the same, but the fan bearing (behind the big sprocket) has a different part number. The quick hitch shaft bearings (2) also have a different part number, but that doesn't necessarily mean anything, although prices for all 3 are different. I'll get them all pulled off then we'll see. I'll be surprised if they aren't all actually the same.
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2015 DODGE RAM...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
Polecat swift 206R (A50322)
Polecat swift 206R...
2025 LandHonor RB-14-78W 78in Rock Bucket Skid Steer Attachment (A49462)
2025 LandHonor...
