BX42 coming - cut pto shaft?
   / BX42 coming - cut pto shaft? #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
My BX42 is going to be delivered tomorrow. Havng nothing else to think about I was wondering if anyone else is using this with an L3400 and did you have to cut the shaft to shorten it at all?
   / BX42 coming - cut pto shaft? #2
On my B7800 I had to cut both ends of the shaft (equaly) so as to fit the distance between out put and input.
I don't know the size difference between the 7800 and L3400 but I'd think they weren't too far apart.
   / BX42 coming - cut pto shaft? #3
I would wait until you have both units there and then, measure twice and cut once. If you cut at all? Ken Sweet
   / BX42 coming - cut pto shaft? #4
   / BX42 coming - cut pto shaft? #5
Also, if you plan to add a quick hitch e.g. Pat's, the PTO shaft will need to be longer than without the hitch, so I suggest getting the quick hitch installed first before cutting shaft.
Thanks - all good advise!
It was just delivered to my workplace, now I just have to have one of our trucks bring it home.
I was (optimistically) hoping that someone who had the L3400 would chime in and say how perfect the fit was without cutting :) I would be content not having to cut.
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
Unused Delta Crash...
