BXpanded Hydraulic Pressure Test Kit
   / BXpanded Hydraulic Pressure Test Kit #21
Does this kit show you where the pressure relief valve is on the BX 60 series? I already have a pressure gauge from when I had a JD and my BX tested out a year or so ago right at spec. But if/when I do need to compensate for an aging relief valve spring, I'm not sure where the little sucker lives on my BX. Anyone know?
   / BXpanded Hydraulic Pressure Test Kit #22
Why not make your own for $40.04? Try Discount Hydralic Hose.
Parts:
701-04-04S | 1/4" Female Coupler x 1/4" NPTF Female (Steel) 8.32 (Loader)
702-04-04S | 1/4" Male Coupler x 1/4" NPTF Female (Steel) 4.07 (Remotes)
AFC-3M-25 | Bottom-Mounted Pressure Gauge, 0 to 3,000 psi 17.50
Shipping USP $14.15
Allows you to check either male or female fittings. Shims are $.35 at Messick's and come in different thicknesses (.01mm .02mm and .04mm). I think pressure boost is 39 psi/.01mm shim.
Great info - thanks! I ordered today
   / BXpanded Hydraulic Pressure Test Kit #23
Code54
My hyd pressure was 1625 psi. Kicked it up to 1740 psi. Was afraid to go too high.
LA243 loader max is 1778 psi.
BX2660 spec is 1780 - 1840 psi. I checked at rear remote at max speed and fluid hot.
CHD
On BX2660 the pressure relief is the lower nut on the left of the pto guard. Not the nut above that looks like some kind of cap. Don't know if the BX1860 is the same.
   / BXpanded Hydraulic Pressure Test Kit #24
BTW I messed up earlier on the shim thicknesses. Should be .1mm, .2mm and .4 mm. Sorry :confused3:
Jim
   / BXpanded Hydraulic Pressure Test Kit #25
Jim
No problem.
Just glad to have found a less expensive source
Thanks again
   / BXpanded Hydraulic Pressure Test Kit #26
CHD
Thanks YJ - will have a look next time I'm out in the shed. I would guess all the BX's are the same regarding placement of the relief valve.
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
1605 (A57192)
1605 (A57192)
NEW Fork Extensions (A59000)
NEW Fork...
Deere 310L (A53317)
Deere 310L (A53317)
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
