By request, images of deer-proof garden
   / By request, images of deer-proof garden #1
KeithInSpace
Fred'burg, Virginia
Kubota BX2230
Know this probably should end up in a general projects directory, but it is a response to a direct request from my lawn project update images and is really a continuance of that previously posted thread...
This is the garden I put together for my wife.
The in-ground stuff: Pre-backhoe, I had dug a 2' deep swimming pool in the bottom as best I could and set 6" x 6" timbers to bound the hole. Though you can only see one timber, they are stacked two tall with 1/2" re-bar pinning the two layers together. The timbers were all 16', so they are laid as 8' x 16' on the ground. Originally, I had placed ~3CY of engineered fill (part topsoil, part sand, and part cooked compost). Turned out that it turned to STONE after it set up for a while (despite the sand and compost) and we could not grow ANYTHING in it the first year. Quite sad to have this BEE-AYY-UTIFUL garden area and thousands of dollars of equipment with sad, dead sprigs of tomato plants in there.
The frame: All 2" x 2" treated pine held together by nothing other than DeWalt finish nailer-fired 2" 18 Gauge brads nails. No screws, no big nails, no pins, nothing. The only screws in the structure are those associated with the door hinges and hardware. All cuts are 45 degree. In the areas where I didn't need to worry about headroom, I maximized structural stability by making the corner braces long. In the center area where I wanted headroom (and by the door), I made them shorter. It is a VERY stout structure. I recently whacked it several times with my BH bucket, once bending the front center support a solid 6" or more inward. The whole structure moves as a unit, doesn't collect any wind, and seems like it will be happy to stand for another 10+ years with no further attention. I will probably pressure wash it and water seal it soon. I put some lathe at the top to form a "roof" of sorts, but it is unnecessary. Going back, I would not have done that.
The screen: I bought it in rolls at Home Depot. It is literally sold as "deer screen". It is flexible plastic and you can't really see it unless you're right up on it...otherwise just it looks like an odd open wood structure at the end of my driveway. The holes are about 1/2" x 1/2". The screen door had regular "screen door screen" on it for the first year. It caught a bunch of wind and eventually ripped out. A couple of weeks ago, I replaced it with deer screen and it works great. I'd suggest doing that out of the box. The screen is held in place by staple gun staples, nothing more.
The entire project took a single day to complete after the hole was dug. We have had 80 MPH winds since I built it and it is fine (though the trees block most major wind, but it ain't going nowhere).
Recent work: I backhoe'd out all of the granite-like soil to a depth of about 2 feet. I even got the corners that I couldn't get with the FEL the first time. I replaced it in layers of peat moss, topsoil, and my own leaf/grass compost. We recently planted this year's veggies and I think it will do much better.
Future: The whole thing will grow by another 8' to the rear by next growing season. And may get a shed planted beside it...the tractor will probably move into the shed. And I will bury a PVC water line to the structure so I don't have a hose across my grass all summer.
   / By request, images of deer-proof garden #2
this looks good --
-- i am planning on putting a raised bed garden in this spring, with 4x4s every 2', coming up 18" high. i'll use trex as the cladding, and the whole garden will be above-ground -- it'll be 4' in depth by 48' wide.
for the top, i'll use something similar to your deer netting -- i also was lucky to find 2x2 trex pieces that i'll heat up with a propane heater and bend to form trellises.
i am surprised that your soil mixture turned to stone -- i am looking at around 11 yards of a "magic mix" supplied by a local gardening store -- i'll make sure it doesn't set up like they're saying.
again, good job, and i'll post mine up soon!
   / By request, images of deer-proof garden #3
I was thinking of something similar but less elaborate - chicken wire on t-posts with bird net on top. Roll the bird net back when you go into work on it (or maybe put a ridgepole down the middle to get working height.
Any thoughts on this approach?
That's what I was thinking of originally, but the wife didn't want any "rolling", "ducking", or any other maneuver involved. She picks all manner of things at dinner and such to make fresh pasta sauce, etc., so she didn't want to have "stuff" to do for access to her veggies. She wanted to open a door and be inside...close a door and it be secure.
That's the only reason it ended up being what it is. SAGWESW rule applies. (she always gets whatever she wants)
Can't complain...she gets me the TOOLS I need to provide whatever she wants, whenever she wants. It's symbiotic, and a pleasure.
   / By request, images of deer-proof garden #5
You're a wise man!
I'll have to figure out a way to to it without rolling/unrolling. Maybe some sort of tent pole.
Very helpful, always nice to catch these things in the design stage.
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
John Deere 853 20ft Corn Head (A55315)
John Deere 853...
2018 Chevrolet Camaro 1LT Coupe (A55853)
2018 Chevrolet...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2010 Freightliner Derrick Digger (A55973)
2010 Freightliner...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
