Bypass breakaway to narrow down electric break issue?
   / Bypass breakaway to narrow down electric break issue? #11
There will likely be a ground connection across the ball & hitch. However because it moves & is covered in grease it's likely to be flaky. Simple answer is do it right. Wire the plug ground to the frame.
   / Bypass breakaway to narrow down electric break issue? #12
I rewired the brakes tonight and got all 4 to activate off a battery. Still no go from the truck. I tested the output at the 7 pin and only got .1 volts. So I then tested the blue wire out the back of the controller, got 11.5 volts. So it appears the controller is sending the voltage out and it's getting lost somewhere in my truck. The 12V battery pin wasn't getting voltage either. I checked the fuse box under the hood, the trailer brake fuse appears good, the 12V aux fuse wasn't there. Truck is a 97 F350 with a factory 7 pin harness. Can I just run a new wire from the cab to the back of the truck?
   / Bypass breakaway to narrow down electric break issue? #14
New wire or finding the issue in the old wire are your only options... And like you determined with the trailer replacement is often cheaper & faster than repair when dealing with wiring.
2007 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWF37P27EA64904 (A54865)
2007 Ford F-350...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
Heavy Duty Jumper Cables (A55788)
Heavy Duty Jumper...
New/Unused CFG Industrial QK16R Mini Excavator (A54865)
New/Unused CFG...
Test Button (A47477)
2002 Ford F-450 Lift-All LAH-30-15 30ft Bucket Truck (A55788)
2002 Ford F-450...
