Bypass oil filter on car or tractor
   / Bypass oil filter on car or tractor #1
valley
Platinum Member
mountain valley near Tahoe
Michigan 55A, Foton 254
Greetings, Has anyone added a bypass filter to their car or tractor? What kind? What results? Thanks Richard
   / Bypass oil filter on car or tractor #2
those filters can be expensive, but so is destroying the engine. i wouldn't do it.
   / Bypass oil filter on car or tractor #3
some of the old (40's 50's) Mack fire trucks I worked on had them they used the oil pump to supply pressure to engine and some went to filter and drined back in to crank case.
I would thing you would need a large volume pump or separate pump to do it today.
I guess they thought dirty oil is better than no oil if filter got plugged.
tom
   / Bypass oil filter on car or tractor #4
I know that Amsoil sells bypass kits for some vehicles (I think BIG trucks and most diesel pickups).. You could check out their website for information.
A lot of ppl that run synthetic oil and extended oil changes swear by the kits..
brian
   / Bypass oil filter on car or tractor #5
Amsoil sells bypass filter systems and there pretty popular among the diesel truck crowd. Go to any Ford, Chevy, or Dodge diesel forum and you'll found numerous amounts of people that run them. I plan to put one on my 06 Dodge when I get around to it because the bypass filters so much better than just a full flow alone.
Thanks, The stock filter would remain in place. The bypass would filter a smaller amount taken from the pressure plug. The stock filter would go on with its job that way if the bypass fills up there is no problem.
   / Bypass oil filter on car or tractor #7
Exactly, that's the only way to do it IMO. Amsoil offers kits that mount directly to the OEM filter housing and then relocate the full flow to a separate mount that includes the bypass filter too. If you run a setup like that than you risk running into the engine being starved for oil because of the excess length, or inability, to build oil pressure. Running 1 bypass filter inline with the already existing OEM full flow is the only safe way to go.
   / Bypass oil filter on car or tractor #8
In 1972 I installed a Frantz oil filter on my Ford Maverick. The unit teed into the oil pressure sending unit and returned oil through a fitting in the oil pan.
I drove the car 7 years, put a new roll of toilet paper in the car every 1500-2000 miles, topped off the oil, changed the regular filter every year, topped off the oil and the oil looked like new when I traded the car in.
The oil drain plug on the car had never been loosened.
Unfortunately I did not remove the unit prior to trade in.
I have no reservations about recommending the Frantz filter.
Their web site offers complete info on the unit.
Frantz Filters Manufactured by We Filter It! Inc - Oil, Diesel and Gas Filters
   / Bypass oil filter on car or tractor #9
Back in 73/74, during Uncle Sam's NAVAir/USMC internal combustion engine maintenance training, one of my Navy instructors "swore" that running an aux filter that used a toilet paper roll as the filter medium would do away with oil changes. Said that all his vehicles had them and all he did was change the toilet paper roll regularly, the regular filter yearly and only top off the oil when needed.
I never did try it but it's lingered in my brain housing group since.
You wouldn't have ever been stationed at NAS Memphis now would ya :D :D
I have a few Frantz Filters. 4 on vehicles on the property and one a friend just gave me. I have never had one on a deisel but I'm thinking of putting one on my latest tractor. Is anyone useing one of these? No! Never was stationed in Memphis.
   / Bypass oil filter on car or tractor #11
For those who may not know, a bypass filter is one that is supplied with a small volume of oil processed through the filter media and returned back to the crankcase at zero pressure. It is never part of the pressurized lubrication system. Bypass filtration bypasses the high volume full flow oil circuit. Someone stated that they would install the bypass in line with the full flow filter. Doing that would not work as the bypass filter head has a very small orifice to reduce the flow through the bypass filter. Thus, it would starve the main oil rifle passage (oil gallery) and destroy the engine. It is correct that this type of filter system needs sufficient oil pump volume to be able to spare a small volume of the oil to be diverted away from main engine lubrication. Some diesel truck engines (18 wheel) have bypass systems that operate on 2 GPM maximum flow. Engines of that size can spare that volume without jeopardizing the lubrication requirements of the engine. To install such a system on a small diesel or gasoline engine would require a much smaller control orifice to prevent oil starvation of the main full flow filter.
Thankyou for the best description of a bypass filter I have ever read! Having clean oil is the goal, long oil live is an added benefit. I appreciate you taking the time to post.
John Deere 5105M (A53317)
John Deere 5105M...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2003 Big Tex 10PI...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
