Cab, 12x12 shuttle and self-leveling loader?
   / Cab, 12x12 shuttle and self-leveling loader? #31
In regards to Kubota versus JD. Kubota tends to have a high HP to weight ratio. JD tends to have a high weight to HP ratio. Depending on operators and uses, each has it's advantage.
   / Cab, 12x12 shuttle and self-leveling loader? #32
Felling and skidding trees...when I've done that I wound up wanting as much FEL capacity as possible because I was often lifting trees on the forks to cut them and move large sections, or lifting one off another. My loader had 2500lbs of lift to full height, and it often wasn't nearly enough. Backhoe with QA forks is being delivered in about an hour to fix that problem :thumbsup:
Nice! That's an option I hadn't thought of. I've seen backhoes with 3pt hitch and box blades doing snow in parking lots. I wonder if there is a PTO kit for any of them that I could run a blower..... More lift and much cheaper than comparable farm tractor around here. Just would need to put some R1s on it since the standard R4s suck as soon as it gets a bit muddy
   / Cab, 12x12 shuttle and self-leveling loader? #37
   / Cab, 12x12 shuttle and self-leveling loader? #38
She's a beaut Bart. Looking forward to specifics once you get her goin. I especially like the powershift split on each forward speed. Often wish I had that.
I think that's a great machine, but I actually went a slightly different route for my larger machine requirements....delivered earlier today:
   / Cab, 12x12 shuttle and self-leveling loader? #39
Bart, that's cool too!!! Is it a 4 stick setup with treddle swing??
   / Cab, 12x12 shuttle and self-leveling loader? #40
Yep...standard Case controls, e-hoe, dual batteries, hydraulic QA front bucket and forks...the whole enchilada minus AC ��
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2018 Bobcat T590 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T590...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
HYDREMA 912HM ARTICULATED DUMP TRUCK (A52707)
HYDREMA 912HM...
John Deere 1025R (A53317)
John Deere 1025R...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
