cable laying
/ cable laying #21
schmism said:
I know trenchers and vibatory plows usually pull there pipe/wire thorugh the ground, so the more pipe you pull in the harder it gets...
I've pulled miles of pipe and wire with my subsoiler. You'd be surprised how little resistance there is in moist soil. It creates its own tunnel as it goes. The front vertical edge of the subsoiler shank must be sharp to slice neatly through the sod.
gabby
/ cable laying #22
schmism said:
edit... id make the wings adjustable so i could varry the depth based on need.
Don't bother with the wings. They will just drag up piles of loose dirt as you plow and make a mess. You can control the depth with the 3ph. The vertical shank must have a sharpened cutting edge to make a neat slit.
gabby
/ cable laying #23
Harry C...I would like to see how you laid the pvc pipe. That is something that I constantly struggle with, I use a plow and then go back and clean the trench and finally lay the pipe. If you can do all this in one shot, you have my attention.
/ cable laying #24
Pulling the pipe's no problem at all for fairly straight runs. I used 1 1/2", 1" and 3/4" PVC with glued fittings. No leaks, no broken pipe.
Use a subsoiler with a sharpened front edge or preferably improvise a coulter if you have sod. (I built my own plow with some slightly different angles). About an inch from the bottom of the subsoiler drill a hole that'll let you put a 1/8 inch plastic covered cable through. Use a piece of cable about 2 feet long. Put the end through the hole in the plow and clamp it with a cable clamp leaving the tag end to attach to the pipe. Drill a hole through the center of a pipe cap to serve as a bullet nose and to keep the dirt from filling the pipe. Thread the cable through the cap.
Lay out your pipe where you intend to pull it and glue it all together on top of the ground. Drag the pipe backwards until the end is about 5 feet behind where you intend to start the pull. Drill a hole through the side of the pipe about 3 inches from the end. Back the tractor up to the pipe and attach the pipe to the plow. Thread the cable through the end of the pipe and out the hole you just drilled. Take about 4 half hitches around the pipe. Make a wrap around the pipe with tape over the tag end of the cable so the knots will pull up evenly. Slide the cap down the cable over the end of the pipe. The end of the pipe should be about 3"-4" behind the plow.
Plow! It'll pull right in.
When you get to the end of the pull, dig down, cut the end off the pipe (remember, you drilled a hole in the side!) and make whatever connections you need.
Note! You cannot back up once you start. If something goes wrong or you hit obstructions, raise the plow and pull the pipe all the way through back onto the top of the ground. Drag it back and start again. I found that in areas I expected dificulty with tree roots etc. it was best to make a pass with the plow prior to hooking up the pipe. You can even pull with TEES already installed but make sure to lay out the pipe and mark the TEE locations or you'll spend lots of time with a shovel trying to find 'em.
/ cable laying #25
sorry...I must be a little slow today...you lost me when you asked to drill a hole in the pipe. So what you are saying is that the reason for the cap is to attach the cable to the pipe, which will act as the connection between the pipe and the plow? Thanks again and appreciate the advice.
/ cable laying #27
Sorry I didn't explain it very well.
The cable goes into the pipe and out the hole in the side to allow the cable to be tied around the outside of the pipe. That's the connection between the plow and the pipe. As you pull, the half hitches tighten down on the outside of the pipe and the cable doesn't slip off. You could just tie around the outside of the pipe but then the pull would be off center from the pipe and it would tend to hang or deflect as you pull. The cap is to keep dirt out of the pipe and to keep the cable reasonably centered with the pipe. It just slides onto the cable and slips back over the end of the pipe after the cable is attached to keep the dirt out.
Sorry, no pics of the plow... No more pipe to put in so I made it into something else.
/ cable laying #28
Perfect!! Now I understand. thanks again for the great info...guess I'll have to start looking for this implement.
/ cable laying #29
My father and I plowed in an invisable dog fence around their two acre yard with an anhydrous amonia knife. This worked well with the coulter in front to cut the sod then the knife which is only one half inch wide cut a nice slot around two and a half inches deep. The back of the knife has a pipe for applicating the anhydrous amonia so the only modification needed was to bend the pipe to a nice angle for the wire to be laid. Looking back it would have been nice to add two gauge wheels that would keep the proper depth and also doubled as closer wheels for the trench. At the time all he had was a John Deere 425 and it didn't have enough traction to pull it so I assisted with my fourwheeler. Worked very nice and the trench wasn't noticeable after a few days. Be careful with your splices with such little wire you will have a lot of loss at each splice without soldering and proper sealing.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
2005 Big Tex 14TL (A60462)
2005 Big Tex 14TL...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
