Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Soundguy - we pretty much agree to disagree.![]()
will probably have to.
A little hard to change a 500 pound tire. OOPP's we need another tractor or some kind of lift to get one off and one on.
um.. actually not hard at all. I do it all the time. I weight about 130# and 5'6".. I just changed the tires on my ford 4600 a couple weeks ago.. did it with a long prybar.. had a loader if I needed it but didn't. keep em upright and rolling. I NEVER unload a tire to simply change it.. only if it has a leak. big tires like 18.4x30 hold 742# of water per side. not counting the rubber or the rim.. or the ballast.. I usually leave the center on the tractor unless dishing. As mentioned.. the 16.9-24 are 509# of water per side. 14.9-28 442# 13.6x28 360#, 12.4-28 292#, 11.2-28 225# those are the common sizes I have on the bulk of my machines.. At this rate.. the 11.2-28 feel like dog food bags after changing some of those 14.9 or 16.9's
I keep at least one, and in some cases a pair of anything I run onmy machines in the back of the pasture, on rims and aired up leaning against the fence in case of emergency. took a couple years to build up that colelction.. but is worth it. mostly auction and craigslist finds.. usually good deals too.. tires and rims and centers.. 4 of them for 125$.. used and a lil rust.. but hold air.. stuff like that. just gotta watch for them and get them when ya find them.
If someone has time to play you can rush the water out a little. It still takes a few hours.
we'll really just have to disagree there. I've unloaded, broke down, re tubed, and reloaded them big tires in a couple hours...
Man handling a tube with several gallons of water in it is not much fun.
nothing about a flat tire is fun...
Tubeless tires can usually be plugged. But some fill material, antifreeze, water or what ever may keep the plug from sealing.
I'm not a big fan of plugs. having worked around heavy equipment most of my life.. I've never seen a plugged ag or industrial tire hold up as well as a patched casing / new or repaired tube. ( I'm a fan of replacing tubes due tot he amout of work it takes to get into the tire.. ).
small tire? like a front.. sure.. a plug is fine.. I don't routinely load fronts unless really needed.
Yes I have been there and done it. I would never put anything like water or antifreeze in one of my tires.
down here where I'm at.. wheel weights are like hens teeth.. hard to find.. everyone just loads the tires... I'd love to find a local set of wheel weights that's affordable for my tractors. In fact.. i just foud a set of fomoco front weights for my 4600 and installed them today. they are not without their own problems though. have to remove them to do anything to the tire or rim..
I respect your way and ideas - Just not for me.
no disagreement there ... to each his own.. what works for one person may not work for another. region makes a big difference too. as mentioned.. no wheel weights to get down her e in fl unless you pay thru the nose.. thus we have found another way to accomplish the same thing... if they were plentifull and cheap, like they are int he farm belt.. then it might be very different. I have friends int he north that atre near massive tractro bone yards that are full of good stuff. usually pallates and pallates and acers of cast iron weights for pennies on the dollar. problem is shipping charges kill ya.
I'm saving up my spare lunch money to get a set of segmented ford weights from a buddy up north one of these days. will just have to bite the bullet and pay the fright charges to get them as I surely havn't been able to find them down here..
soundguy
