RobS
Super Member
I'm hardly an expert here, but the salt used in a water softener does not go directly into the house water supply. When the unit recharges, the salt water solution (insert a whole bunch of chemical-ese including the words "ion exchange" here) is drawn into the softener unit. This brine solution reacts with the materials in the softener chamber (more chemical-ese here) to draw out the minerals and whatever else it removes. Final step is to flush the softener chamber with fresh water. Now the chamber is ready to accept household water where it will draw out more minerals and stuff. Some salt will likely remain to mix with your water, but the amounts should be small. There is probably more a water softener WON'T take out than what it will (ie. iron and a whole multitude of other minerals). I learned this some time ago from a softener guy but don't remember many of the details. We do have a softener in our house.
The bigger issue with softeners is that all the recharge and flush water goes right into the septic system. I've heard it's not good for the organisms munching away on your "stuff" in there, but we've not had any problems. Our softener only recharges on demand so it may not run as often as one on a simple timer.
There's probably a water softener-by-net out there somewhere to get better answers to these questions/w3tcompact/icons/smile.gif
Rob
Rob
