Can anyone identify this FEL hydraulic control valve?
   / Can anyone identify this FEL hydraulic control valve?
Well no. Per my previous post the valve has now been rebuilt, and as mentioned at the start this valve came as part of my FEL kit. So there is no need to pay for another control valve...
Identifying the valve simply makes finding parts and specifications easier, if and when I need them. And also because I like to know exactly what I have.
   / Can anyone identify this FEL hydraulic control valve? #12
Was your valve designed as a loader valve?
Does your valve have float and regen.
Do you know the relief settings for the loader valve?
Do you know the relief valve settings for the 3pt relief?
Getting off topic now. The thread topic was identifying the valve.
I have no interest being diverted down this road any further apart from saying this was the OEM valve on my FEL.
The exposed threads of the screw adjustable relief valve were duplicated on re assembly.
A master pressure gauge will be used to check all is within normal pressures when the FEL is finally fitted.
Without a manual I cannot do much better than that. Nor will I throw away hundreds of dollars (simply for a lack of ID) on a new valve when this one worked just fine before its rebuild, showed no signs of wear and has been reassembled verbatim.
If you can offer more for identifying the valve please let us know...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
