Can I burn old oil filters?
   / Can I burn old oil filters? #11
No--none--zero of anything like that in my part of Ohio.
It's all landfill and picked up by contract refuse trucks.
Some townships recycle the basice for two hours one day per month.
I live in Ohio. Walmart takes old oil, filters and antifreeze. My local dealer I purchased my tractor from also takes back old oil and antifreeze and the filters as well.
I believe Autozone also takes back old oil but not 100% sure.
It's actually easy to get rid of old oil.
You should be aware of the contaminates that are in used diesel oil, before burning the filters. we have to drain and crush ours before recycling them.
That's why I'm thinking of burning them. There are waste oil furnaces everywhere and that seems to be OK.
The issue probably is the attempt to avoid any oil getting onto the ground and contaminating groundwater.
So....if I drain the cannister correctly and then place upright to burn, the oil would burn, not a drop would spill and I could recycle the empty cannister.
That's what I'm thinking and I'm trying to do the right thng.
   / Can I burn old oil filters? #13
Heck yes! I do it all the time in my shops hot blast wood burning heater its extra btu's thats how I get rid of them and the case can be put in the trash its a win-win.
Now when I used to burn them in a 55 gallon barrel.... don't let your hired help light a whole barrel of them I am pretty sure the men in the space station saw that mistake. :mad:
Fact here is a pile of them right now.
   / Can I burn old oil filters? #14
This did not search well the so if old news I'll delete.
My summer project is to cancel trash pickup, recycle everything I can and burn the harmless remainers. Bury the vegetable stuff.
I'm no green weenie, just tired of paying for a guy to pick up a half shopping bag of trash each week.
One of the problem issues is old oil filters and what to do with them.
I wouldn't want to spill old oil on the ground but figure to stand up the drained filter in my burnable trash and light the pile.
Seems the pile burns, the oil and media burns and I can put the remainder metal can in with my metal trash.
Is this a good idea??
Just be sure you check the law before doing so...Also, I would compost your green waste rather then just burying it...:thumbsup:
   / Can I burn old oil filters? #15
I do get a kick out of the green crowd sometimes. Anyone really think there's any difference between burning the litle bit of residual oil in a filter vs an older car that burns oil and burns that much in 10 miles of driving?? :confused::confused:
   / Can I burn old oil filters? #17
i've benn heating my shop that way. i bring all th efilters home from work and throw one in every hour or two. its just like a half a stick of wood.every btu you dont have to pay for the better. i dont even bother to drain them, the more oil the better
   / Can I burn old oil filters? #18
What is it in waste oil that's bad? I have read that you shouldn't get waste oil on your skin. Is that why I see more mechanics wearing gloves? Whatever it is does it burn up? Where does it go?
Chris
   / Can I burn old oil filters? #19
Hi all,
Although I am new to the forum here comes my two bits:
If you leave your filters and old oil for recycling/destruction it will most likely go to a big furnace that burns at a very high temperature. Higher temperature means different burn chemistry and most destruction furnaces are equipped with both catalysts and filters. Your filters and used oil will contain a lot of what in lay terms are called "crap" but for the recycler/destructor are heavy metals that mostly are separated out and recycled and a lot of really nasty poisonous compounds that are converted by high temperatures combined with catalysts to less nasty compunds.
In your average wood furnace or oil drum you will most likely just release all the nasty "crap" from what you burn and it will fall on your own and your neighbors land. If you grow anything on your land that you eat you will then ingest the 田rap and even if this also is a kind of recycling of the "crap" it might not be very healthy.
Please count me into the "green crowd" but last time I counted I only found one earth and my children will need it!!
   / Can I burn old oil filters? #20
I'd burn them and get the heat value. Bury the carcass if no recycle to drop it off. Will release more "crap" in the air driving to the recycle than in the burn. IMO
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
JMR tree boom attachment (A53421)
JMR tree boom...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
20702 (A51694)
20702 (A51694)
