Can I remove gravel?
   / Can I remove gravel?
I have an excavator. I could probably stack the teeth thru the soil to loosen the rock up. I really don't want to remove too much soil if I can avoid it. I guess I will just have to toy with it and see what happens.
   / Can I remove gravel? #12
If you figure it out, please update us. There's an area about 30x50ft in our "front yard" where the house framing contractors spread a yard or two of largish gravel in the mud where they had their construction trailer. Now it's well-submerged in the soil and makes it hard for grass to grow. No way I can figure to remove the gravel without digging down 4-6" inches in the dirt, leaving a hole to become a new mudpit. I don't really have a source of clean fill dirt to replace it with. And no good way to dig it. Front loader or box blade (both with teeth/rippers) have difficulty getting down in it.
   / Can I remove gravel? #13
Actually, I grow grass over lots of sites like this--as long as not TOO much gravel. Sometimes I chisel plow first but I rototill, pack and then seed. The rototilling at a slow speed with the lid down will bury all the gravel and rocks and you'll never know it was there. You must pack to press any visible rocks flat with a packer, however. Grass grows fine and never a problem.
I have also picked it up and there is no easy way for that. The above does work, however and I've done it many times. I usually bury rocks softball size and down.
   / Can I remove gravel? #14
Chances are good the tractor and bucket will work fine. If the area is wet the excavator may have to be used.
   / Can I remove gravel? #15
Tooth bar on a bucket will work way better than a straight edge. I'd dig it out, pile it up on a hard surface if possible, and wash it out to get the dirt out. Then I'd stock-pile it for later use. Or run it through a screen to separate the large from the small and dirt. Or I'd just stockpile it dirt and all, and only take the time to sort/wash it if and when I ever was actually going to use it.
   / Can I remove gravel? #16
What about covering it with top soil?
   / Can I remove gravel? #17
Wait till it's bone dry in the summer and use your excavator.
   / Can I remove gravel? #18
You can move #3 with a box blade -- I have done it. Easier when loose (in fact, box blade spreads it rather nicely) but doable after it's settled.
Rail ballast is the next size up from #3 and I haven't attempted to move that stuff. It's a little beefier than I think a box can handle smoothly.
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
Woods LR72 72" 3pt Rake (A50774)
Woods LR72 72" 3pt...
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
Auger Skid Steer Attachment (A50322)
Auger Skid Steer...
2017 Isuzu NPR Stake Body (A47384)
2017 Isuzu NPR...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
