stuckmotor
Super Member
- Joined
- Sep 23, 2009
- Messages
- 5,304
- Location
- Lower Up State S.C.
- Tractor
- AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
Ssssort of. 'Heavy' thread lubes are very much a YMMV thing vs 'lightly oiled'/torquing to spec, since not all thread lubes are the same. Bolt tension will be higher if a bolt turns way easier with an EP (extreme pressure) lube on threads, but usually no harm going to full torque.
Loader bolts are expected to get seriously yanked on in use so they won't snap easily if not substantially over-tightened. You might just stick to the 'lightly oiled' to minimize corrosion if you imagine grease or A-S would allow them to work l too easily or attract grit.
I appreciate your advice but have trouble with abbreviations. I can't figure out what WMMV and A-S mean.
