Sebculb
Hey everyone again,
Sooo thanks for all the advice so far as I get into this gas welding thing.
Y'alls have convinced me I need a new acetylene regulator and it should probably be a high quality brand name one.
Can I use my current malfunctioning acetylene regulator on a propane tank if I wanted to make an oxy propane setup? It regulates the pressure fine while the torch is flowing. However, when you shut off the torch the pressure starts rising up past 15psi into the red zone, making it dangerous for use with acetylene. But is there any reason I couldn't use it for propane? As far as I know propane doesn't have any stability issues at pressure.
Acetylene is way expensive here so maybe I want a propane setup for cutting and brazing and save the acetylene for welding. What else do I need besides a different regulator? (I read propane can damage an acetylene regulator) Do I need other hoses? I know propane tips are different, are they simply recommended or absolutely necessary?
Thanks!
Thanks!
