can my 28 hp tractor pull a 5-6' double row disc?
   / can my 28 hp tractor pull a 5-6' double row disc? #1
Scratchnbell
Fish Camp,California
New Holland 2001 TC40d
can my 28 hp tractor pull a 5-6\' double row disc?
Ok, I've got my new tractor.
There is a either 5 or 6 foot disc forsale down the street. It has a single row the is parallel with the back of the tractor and a second row that runs slightly at an angle to the first. Will a 28 hp tractor handle that thing?
thanks
Bob
   / can my 28 hp tractor pull a 5-6' double row disc? #2
Re: can my 28 hp tractor pull a 5-6\' double row disc?
If you try it and can't pull it, you could probably easily remove a disc or two and make it effectively narrower.
- Rick
   / can my 28 hp tractor pull a 5-6' double row disc? #3
I pull a 6.5 foot similar disk with my Kubota B2710. IT has 27 gross, 20 PTO horsepower, and HST. The tractor pulls it just fine. Picks it up just fine also.
   / can my 28 hp tractor pull a 5-6' double row disc? #4
I pull a very heavy two row disc with my old Ford 2N ( about 22 hp ) . The disc probably weighs around 750-1000 lbs. . I have power to spare but it was impossible to steer until I filled the front tires to add weight.
You should not have a problem so long as you have ag tires and enough weight up front to keep the wheels on the ground.
You may have to fill the rear wheels with fluid to have enough traction.
Fortyseven2n
   / can my 28 hp tractor pull a 5-6' double row disc? #5
Tell us a bit about your "28 hp tractor" and we may be able to offer an opinion.
I pulled one with a 20hp tractor, no problem. But depending on what you have your 28hp in, it may be a problem for you. Also, the position of the blades and weight on the disc will make a big difference on how hard (or easy) it pulls. Also, the ground you are working up and the traction you have relative to that ground will make a big difference.
A 5hp tractor with the right gear ratio and the right 'contact' with the ground will pull it. Probably slower than you might want to go. /forums/images/graemlins/wink.gif
How about it? /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
   / can my 28 hp tractor pull a 5-6' double row disc? #6
It should pull them no problem. I have a 22HP 2 Cylinder Chinese tractor and it pulled them fine. The soil I have is rocky and clay. Sure beats a rototiller in those conditions. Pictures are on my site under tractor album.
http://users.adelphia.net/~gizmo/
   / can my 28 hp tractor pull a 5-6' double row disc? #7
Another pic...
   / can my 28 hp tractor pull a 5-6' double row disc? #8
Mine was only a 5 ft I borrowed but with your extra hoses a 6 footer shouldn't be too demanding..
thanks John
Bob
   / can my 28 hp tractor pull a 5-6' double row disc? #10
Use your brakes as a steering aid, that's why farm tractors have separate right an left brakes... There is no tractor I know of that will steer worth a **** in loose dirt pulling a heavy load...
I even use the brakes when mowing, this keeps the front wheels from plowing an tearing up the real estate...
Richard
West Michigan...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
UNUSED RETRACTABLE GARDEN HOSE REEL (A54757)
UNUSED RETRACTABLE...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
