Can you cut harden steal flail blades to fit?
   / Can you cut harden steal flail blades to fit? #11
Depending on the amount of material to be removed a chop saw blade will deflect if he is not cutting more than a blade wide.
   / Can you cut harden steal flail blades to fit? #12
We often cut blades with a grinder to make fit different brands in a pinch but got to be careful with flails as it does'nt take much to cause vibration..!
   / Can you cut harden steal flail blades to fit? #13
I use a 3" dia radiac cutting wheel that is only .050/.060 thick on a Dotco air grinder.
It cuts by friction so its possible to get the hardened metal hot enough to get brittle if enough carbon is in the metal. If the metal is thick enough this won'y happen.
With a friction blade chop saw it can get really hot.
   / Can you cut harden steal flail blades to fit? #14
Do you want to cut or grind. Perhaps this kind of grinding wheel. Green Silicon Carbide Wheels. The trick to grinding all the blades is to grind them equally, and as someone has suggested, if not done correctly, vibration will occur.
   / Can you cut harden steal flail blades to fit? #15
EDM would be the best way. Some tool and die makers have EDM machines. I don't know how much they would charge.
   / Can you cut harden steal flail blades to fit? #16
I believe that will get a little expensive for 48 blades, doing both sides, trying to keep them balanced.
Just got back from hunting camp and was pleased to see all the advice I think I might go with the grinder first to see how that goes.
J.J. I'll try and find the blade you said . I think that the amount each one weighs after will matter alot .thanks for all the Info.
   / Can you cut harden steal flail blades to fit? #18
Try this company for blades. I picked up their catalog at the sunbelt ag show a week ago. It doesn't list the blades for your mower but it does give detailed measurement of each blade.
Clean Cutter Tiller Blades
   / Can you cut harden steal flail blades to fit? #19
I don't think a chop saw is rigid enough, not to mention the manual feed is too easy to overload the blade. If the blades are thin enough a waterjet would be a lower cost alternative to EDM. If the blades are rigid and you have a good machine shop they can use carbide endmills. If you want to do them yourself then grindind is your best shot. The blades are probably low allow and will be easy to overheat and soften.
   / Can you cut harden steal flail blades to fit? #20
Best way is to find the right blades. Give this link a look over and see if anything comes closer than what you have. I know the last thing you want to do is to pay for another set, but it might be better in the long run if you can find the right ones.
David from jax
Mower Parts
Just be glad that they aren't as expensive as the ones my flail takes...
http://www.flailmaster.com/products/products_detail.aspx?PartID=15494
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A53472)
NEW 2022 Load...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
REIST R25PSS LOT NUMBER 231 (A53084)
REIST R25PSS LOT...
