Can you dig out a "sink hole"?
   / Can you dig out a "sink hole"? #11
We had one open up in a road down the hill. The township dug it out. It was huge. They filled the bottom with concrete then filled it in with stone and repaved the road.
Chris
   / Can you dig out a "sink hole"? #12
   / Can you dig out a "sink hole"? #13
Doug - I have land West of you in Hope with similar sink holes. No luck filling them in either. Its essentially a half buried hour glass with one part as an underground cone. Conversely, if you were successful in filling it, what processes has it caused to change underground? Does it divert underground streams directly to your new basement?
On our land I can actually align the sink holes across multiple neighbors land and almost plot the line where the next sinkhole could be. This covers nearly a mile of surface distance with 5-6 holes that you can eyeball (or w/aerial photos)..kind of like playing connect the dots. Perhaps you can do this to determine a direction of the underground flows???? I'd also recommend getting sonic maps before building.
Good luck
   / Can you dig out a "sink hole"? #14
i have depressions that keep coming back but in my area i belive it is because of development and water being pumped out of the ground
   / Can you dig out a "sink hole"? #15
We have repaired some sinkholes in drainage retention areas.. the answer as to repair depends on the hole. Some can be dug out and filled.. some are dug out deep.. bridged and pile dwith boulders and backfilled.. etc.
In extreme circumstances, you have to use foundation stabilization systems.. like peirs, to make sure a structure doesn't succumb to the hole if it widens.
I am guessing your homeowners insurance will have an issue with a hole that close in proximity to a structure.
hire an engineer / firm in your area..
soundguy
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
KUBOTA SVL75-2 SKID STEER (A51242)
KUBOTA SVL75-2...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
