Can you get detent rear hydraulics for Kubota BX2670
   / Can you get detent rear hydraulics for Kubota BX2670 #1
Glenn K
Australia
Kubota BX2670
I just bought a Kubota BX2670 and had the rear hydraulic kit fitted. The kit provided 2 sets of rear outlets with controls that spring back to the centre. I want to vary the amount of flow to change the speed of a hydraulic motor on an attachment which also uses the PTO to turn a screw. The dealer did not know of a modification and told me to tie a rope onto the control leaver and put a return line in with tap to control flow. This seems ridiculous and I was hoping someone new a better method or if a detent controller was available to fit this tractor. Can I remove a spring and have variable control?
   / Can you get detent rear hydraulics for Kubota BX2670 #2
It's typical here to get a recommendation to use a bungee cord when using remotes (that don't have detents)...mostly as cheap, simple solution to an immediate problem...
If you have the part number for the control valve...you can look up diagram and parts list and see if a detent and or float kit is available for the valve...
messicks.com is a good place to look...
Good Luck...
JOHN DEERE 520 SHREDDER LOT NUMBER 253 (A53084)
JOHN DEERE 520...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
JOHN DEERE 460M LOT NUMBER 258 (A53084)
JOHN DEERE 460M...
1998 FORD CRANE (A52472)
1998 FORD CRANE...
Kubota RTV500 (A47384)
