Can you increase FEL lifting?
   / Can you increase FEL lifting? #1
Kendall69
Banned
Can you increase FEL lifting, by changing the cylinders, or is this crazy.
Is it the cylinders that determine the lifting capacity? I know it has a lot to do with the weight of the tractor and tipping it over, but if one is aware of that and keeps heavy weight low.
Has anyone attempted this, or is it just nuts?
Thanks for enlightening me.
   / Can you increase FEL lifting? #2
Sure you can by increasing the hydraulic pressure, increeasing the diameter of the cylinders, or changing the cylinder mounting locations. Of course you may break the loader or a front axle!!!
Andy
   / Can you increase FEL lifting? #4
You can increase the amount weight the loader will lift by increasing the diameter of the cylinders or by increasing the pressure. We have had members that have done both with the pressure increase being the most popular of the two options because it is much simpler and less expensive. You have to be careful when you do either one because it puts more stress on the tractor. A small increase in either will net a sizable increase in lift. Note: the larger the diameter of the cylinders, the more it will lift, but the slower it lifts.
   / Can you increase FEL lifting? #5
Afternoon Kendall,
I think the most important thing to remember is that your tractor was designed to handle a certain loader and be capable of lifting a certain amount of weight with the components that are used in its construction ! The tractor was designed with a safety factor, so it is potentialy possible to exceed those lifting numbers by a small amount. I dont think you would find many people on here that would advise that ! ;) If you need to lift something heavier, than its probablly a good idea to be looking at a larger tractor rather than damage what you have now.
   / Can you increase FEL lifting? #6
I would suggest attaching a pressure guage to your FEL system, Make a test guage that can be mounted at quick disconnects on FEL. Adjust pressures to max. allowed in owners manual. Sometimes the pressures are set low from factory.
I understand fully the design of the safety factors, and am glad they are there, but tweaking the pressure a tad would be nice.
I only need to lift 24" - 36" box trees a few inches off the ground, and drive them short distances, no lifting 6 ton over my head or anything nuts like that.
Also I could use the lift for pulling some Palm trees out of the ground and replanting them, again just a short lift.
Are you saying this info is in my lost manual? Or is this adjustment generic at the cylinders?
Yes I am thinking of a new tractor, with more lifting, but the one I'm thinking of won't be made till June or Sept. till then I got a lot of work I can do.
   / Can you increase FEL lifting? #8
When I checked the pressure on my cab JD 3720, the pressure was 2,300 psi. Pressure should be 2500 psi. It was really easy to adjust the psi to 2,750. The main control valve sits under the the cab and is accessible by the rear tire, without removing the tire. Loosen a lock nut, turn in the pressure screw and tighten the lock nut. (Initially, I turned the pressure screw to over 3,000 psi.) This affects the pressure on the loader and rear hydraulics. I don't know if the 3 point lift is affected. I used a $18 gylcerin filled hydraulic pressure gauge attached to a surplus piece of hydraulic hose and mounted a fitting to match a rear hydraulic coupler.
radman1 - How can can I say thanks, except thanks.
I printed this out and will start digging around tomorrow, and see if I can find what you were talking about.
I can't wait.
Thanks again
   / Can you increase FEL lifting? #10
On my L3300 the preasure the preasure is set by shimming the spring for the releif valve mounted on the trans next to the filter. The shims are cheap. The preasure is checked under the seat. Maybe the same on yours. The shims are offered in differant sizes and the change in preasure is listed for each size shim. after you measure what your preasure is you should know what sizes you need if your system is the same. Also you might want to see if you have more lift capacity with the FEL with the 3 point lowered, if so there is a rod that needs to be adjusted. Of course yours maybe completely differant.
   / Can you increase FEL lifting? #11
On my machine, the hydraulic pressure (measured at the dealer) was JUST under the spec. The way to increase the pressure is to add a shim (actually just an appropriately thick washer) in the pressure relief valve system. The manual shows where. My dealer added one shim/washer and this increased the pressure to JUST over the specification. This actually made a VERY significant difference in lifting ability..increased it from about 2400 lbs to about 2900 lbs. I truly needed that extra 500 lbs of lift. Cost: $34. HOWEVER, be aware of the following:
- extra strain on front axel and fel parts if lifting outside limits
- REALLY, REALLY, REALY gotta counter balance with weight in rear, it can be VERY easy to lift rear wheels otherwise..not good.
- turn front wheels at small angle under max load else will roll tire off of rim.
- put max PSI in front tires to avoid tire damage.
Hope this helps.
   / Can you increase FEL lifting? #12
You guys are giving BUM advice , IT'S SIMPLE !
The LARGER the loan, the more she can lift
   / Can you increase FEL lifting? #13
ROFLMAO soooo true..... and especially if you are trying to lift the empty wallet!
   / Can you increase FEL lifting? #14
Have you thought about building or buying somthing that works offthe TPH to do what you need. The TPH will lift more than the FEL.
...The preasure is checked under the seat.
This ones got me stumped, under the seat? There is a "nut" or cap if you will under there, is that it? I'll try and send some pics.
Lifting the rear should not be a problem I have the rear tires filled with water, and a backhoe, so I should be good to go with weight.
   / Can you increase FEL lifting? #16
yes it is possible. also not advisable!!!!! just MHO
   / Can you increase FEL lifting? #17
I really recommend you get access to the manual for your specific tractor... I am sure that the location of the pressure relief valve is not the same for all tractors. Also, my experience is that a small shim makes a large difference in pressure... thus I'd now only do this with the help of a hydraulic pressure gauge although initially I thought it was a "do it myself" activity (without pressure gauge.) You don't want to blow a hydraulic hose with too much pressure.
   / Can you increase FEL lifting? #18
I took pity on your soul. Here are some pictures from the Kubota WSM for the "10" series that explain everything. Click on the pics to expand them. For 200 psi, you need 0.020" shim stock.
Blow up
   / Can you increase FEL lifting? #19
john bud
You are the man!
   / Can you increase FEL lifting? #20
I hope pics below help. This is the way my Ford 1700 hyd pressure relief and 3PT lift is designed. I do not have FEL but still most tractors have identical method in controlling relief pressure to avoid dead heading the positive displacement hyd pump. I have more pics that shows rate of drop mechanism and inner working of the lift piston. please chime in if you need more pics.
This the 3PT lift cylinder head.
Hyd pump discharge just before going to main adjustable relief valve device.
another pic of relief device
Inner components of the relief device. in my case I don't have shims but I can adjust the pressure by an adjustment screw after the cap is removed. screw it clockwise =more pressure and counter clockwise less pressure at the main relief.
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59904)
2019 INTERNATIONAL...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
UNUSED IRANCH MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED IRANCH MINI...
PEMBERTON INC CAT 924H 42" WHEEL LOADER FORKS (A60429)
PEMBERTON INC CAT...
2015 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2015 FREIGHTLINER...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
