Can you name this Whatchamacallit?
   / Can you name this Whatchamacallit? #1
To20Chris
Platinum Member
Hereford, PA
LK3054
I got this device from a family member last year. It is quite effective for breaking up packed dirt. He called it a chisel, but I wondered if anyone knew anymore about it. It's orange, so I assume it's made by Kubota /forums/images/graemlins/grin.gif. Actually, I wonder if it isn't an old road-crew piece?
Chris
   / Can you name this Whatchamacallit? #2
most would call it a scarifier but chisel works to much the same. That looks home made to me but allis chalmers also was orange and if it were factory would fit the area
   / Can you name this Whatchamacallit? #3
It looks like the rippers (some say scarifiers) you might see behind a dozer.
   / Can you name this Whatchamacallit? #4
Jayc, ripper and scarifiers do have a diffrence too. scarifiers will penatrait the ground about a 1' a set of rippers over a foot and are much hevier, i know it's stupid tecno stuff but the 143H cat grader i run at work (thats my main job durring the summer) has both, scarifier for light frost or hard dirt,and ripper teeth for big rocks leadge and such. scarifiers are 1" wide,i have snaped those off, and rippers are 2" wide steel cappable of 18" depth i haven't broke one of those the ripper/scarifier is on back solid mt. to rear frame,cats other option is to mnt. to front frame behind tires and infront of blade,that makes so you can blade off any small stones as yougo the ripper canot be mt. forward because off stresses it would apply.
   / Can you name this Whatchamacallit? #5
So there is a difference? I thought they were the same thing. /forums/images/graemlins/blush.gif
I think I like the term "ripper" better though. /forums/images/graemlins/grin.gif
   / Can you name this Whatchamacallit? #6
Thanks! Did some online searches on Pasture Renovators & got some good info. It may come in handy after the horses work the pasture over this year.
Well, I finally got around to trying the pasture restorer out today. I only got two passes near the edge of the field before it started to pour, but I think I'll let it go at that until I see how it works. I notice that it had the added advantage of pulling up a lot of vine-like roots of other plants that were creeping in from the stone row.
Butterfly Artwork (A55758)
Butterfly Artwork...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2022 New Holland C327 Compact Track Loader (A56435)
2022 New Holland...
202481 (A54757)
202481 (A54757)
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
