I was wondering if there is a way to turn up the hydralic pressure on my 1026.The 260 hoe seems a little weak. 5 or 10% would probably help quite a bit.
A relief valve is what is set to protect the hyd system. It has a suggested manufacturer setting, but people have adjusted it to other settings.
Higher setting should help the hyd system produce more power for the implements. a 100 psi increase, will give a 2 in cyl,. 1 in shaft cyl
a 314 lbs of force X 2
It is recommend to set the relief pressure to about 50 to 100 psi below the pumps max pressure
Hydraulics:
Type: open center
Capacity: 3.25 gal [12.3 L]
Pressure: 2000 psi [137.9 bar]
Valves: 2 to 3
Total flow: 6.3 gpm [23
