can you turn up pressure on JD 1026r
   / can you turn up pressure on JD 1026r #1
bumble bee
cranberry,pa.
john deere 1026r
I was wondering if there is a way to turn up the hydralic pressure on my 1026.The 260 hoe seems a little weak. 5 or 10% would probably help quite a bit.
   / can you turn up pressure on JD 1026r #2
Seems like your pressure setting is 2000 psi
A relief valve is what is set to protect the hyd system. It has a suggested manufacturer setting, but people have adjusted it to other settings.
Higher setting should help the hyd system produce more power for the implements. a 100 psi increase, will give a 2 in cyl,. 1 in shaft cyl
a 314 lbs of force X 2
It is recommend to set the relief pressure to about 50 to 100 psi below the pumps max pressure
Hydraulics:
Type: open center
Capacity: 3.25 gal [12.3 L]
Pressure: 2000 psi [137.9 bar]
Valves: 2 to 3
Total flow: 6.3 gpm [23
http://www.tractordata.com/farm-tractors/006/7/8/6789-john-deere-1026r.html
2003 CATERPILLAR 963C DOZER (A43004)
2003 CATERPILLAR...
2016 Isuzu NPR-HD Morgan 24ft Box Truck (A44571)
2016 Isuzu NPR-HD...
Ford NAA Jubilee Tractor (A46877)
Ford NAA Jubilee...
2011 Mercedes-Benz E-Class Passenger Car, VIN # WDDHF8HB8BA502618 (A44391)
2011 Mercedes-Benz...
2009 International 7400 Truck, VIN # 1HTWGAAR09J160589 (A44391)
2009 International...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A43004)
2018 PETERBILT 579...
