Can't connect quick HD couplers
   / Can't connect quick HD couplers #11
This likely is not relevant to your problem but the link below is to a post I made this winter.
I could not reconnect my snowblower hydraulics when I was certain there was no residual pressure, the couplings were clean, and working fine. A bit of heat on the couplings solved the problem.
http://www.tractorbynet.com/forums//showthread.php?t=231513
   / Can't connect quick HD couplers #12
Hooking the two ends together will still allow the pressure to build up in the heat. Even worse, it has no outlet except cylinder seals or busting a line.
I tried the valve spring type pliers idea once using a set of slip joints and some welding. They were 12" pliers and on a really hot day, Popeye wouldn't have enough forearm grip to release the pressure. Oh well, not much invested.
The rag and hammer or flat surface approach is the only thing that always works.
I was going to try some female couplers with open ends for storage, but was worried the mud daubers would fill them up. I have been looking for an inexpensive sintered bronze filter to keep the critters out.
   / Can't connect quick HD couplers #13
My plan is to mount a pair of female hydraulic couplers to the lid of a 5 gallon pail. Then connect both ends of my grapple when not in use. That way no mess from what ever oil comes out of the hoses.
   / Can't connect quick HD couplers #14
Great idea Zebrative. On the way back from the JD dealer this morning, I saw some balloons at a car dealer. I'm going to pick some up and try them on the ends. Cheap a d should keep the critters out.
   / Can't connect quick HD couplers #15
I am having a heck of a time connecting up my MMM to my 3320 third valve this year. I had teh snowplow angles attached to teh tird valve all winter. I know there is pressure as My deck is hanging. I tride lifting it to take the pressure off. I should be able to wrap in a towl and hit it with a hammer correct? Should I use a regular steel hammer or dead blow? I tried pushing on it and I guess I am too weak this year. Man it was tough.
   / Can't connect quick HD couplers #16
Using the dowel rod in the female coupler usually works using a regular hammer.
I sometimes just push the male coupler against a rag on a flat steel surface, and that works for me.
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2007 Fontaine DFT-5-8048WSAWK 48ft 35 Ton Drop Deck Equipment Trailer (A52377)
2007 Fontaine...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
