cant detach my rotary mower
   / cant detach my rotary mower #1
DumbMF
Jamul CA, East San Diego Mountains
Massey Ferguson 1428
The PTO connection for my rotary mower has spring loaded little tab that holds the drive shaft on my Massey Furgs PTO. Same as my post hole digger. As I look at it, i simply turn clockwise to release the tab and pull the shaft off. I've done this fifty times.
Some debris or something must have got in there because when I went to pull it off...I was not able to turn it at all. Because I can't turn it the tab stays put and i can't pull it off.
I thought maybe was turning the wrong way, but double checked on the post hole digger. The tab springs in and out just fine on that.
I need to figure a way to get that thing off, or how to disassemble the thing or get super strong in a day.
Any ideas?? thanks!
I'm sure y'all know exactly what I'm talking about...but here's a pic.
   / cant detach my rotary mower #3
I would try putting a pipe wrench on it or a big pear of channel locks on it to turn it. If you get it off clean it, and oil it up real good.
   / cant detach my rotary mower #4
hit it with some spray lube penetrant oil... more is better.. then tap on it with a lil hammer.. like a tack hammer.. all around it.. more oil.. time patience... then try it
soundguy
Thanks guys! I'm a little afraid to take a heavy wrench to it as it is made of plastic. I thought I'd just crush the thing. Maybe I'll make that my last resort.
I like the spray lube idea. You think just some common wd-40 all over the place? or would silicon type spray lube do better?
Thanks again
   / cant detach my rotary mower #6
wd 40 is for removing stickers.. silicone spray is to make reels wind better.
a penetrant oil like pb blaster, kroil from kano labs.. or.. if nothing else is available.. liquid wrench.
heck.. diesel is bettrer than wd-40 or silicone spray for a penetrant.
I just free'd up a stuck 3- ball sliding pto coupler on a pto pump on my 3pt backhoe that the prev owner let rust up.
pb oil and tapping got it free.. then I cleaned the rust up with naval jelly.. good as new after greasing now..
soundguy
Well the store is a good 25 miles from me. I found something called Tri-Flow high performance penetrating lubricant. I guess I'll try that. I mean it says penetrating and high performance...that sounds better than sticker remover.
   / cant detach my rotary mower #8
Do you have air try that see if it knocks whats in there loose so you can turn the collar also try the penetrating oil but I do not think it is rusted good luck
FANTASTIC! Soundguy I am forever in your debt. That penetrating lube worked like a dream. Practically did the job without me. I spent an hour trying to muscle that thing off and I'm totally spent. penetrating lube and 1 minute was all i needed. Classic case of work smarter not harder, lol.
THANK YOU!!!
   / cant detach my rotary mower #10
I'm an old iron monger.. most of my fleet of tractors are from the 50's.. I know how to handle rust.. :)
glad you got er'.
soundguy
New 4x6 Chicken Coop (A50775)
New 4x6 Chicken...
PALLET OF SCAFFOLDING (APPROX. 7 PC) (A52706)
PALLET OF...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
UNUSED FUTURE SG45 - 45" HYD STUMP GRINDER (A54757)
UNUSED FUTURE SG45...
2012 JOHN DEERE 160G LC EXCAVATOR (A52705)
2012 JOHN DEERE...
UNUSED FUTURE MINI QUICK ATTACH PLATE (A54757)
UNUSED FUTURE MINI...
