Can't find tank return line
   / Can't find tank return line #21
In a power beyond system using valves that have tank ports you are correct.
Even with a valve with a PB port, say a system with just a loader and 3pt valves, the loader valve can see up to full system pressure, if you're lifting the max capacity with the 3pt. I guess technically only part of the valve will see that pressure- the tank port won't. And it's work ports won't at that time though they could when using the loader.
With open center systems the valves ahead of the valve doing work are essentially just pipes between the pump the the valve doing work.
   / Can't find tank return line #22
I may get to the point of thinking outside the box. Like the fill tube or drain a drain plug.
That'd be appropriate for the tank port if you're using a valve with a PB port.
You need to direct the work flow to the 3pt valve inside the cases if you want to be able to use it with your new valve plumbed in.
If you use a valve with a PB port you can plumb the tank port into a tee in the tank line from the loader valve. Assuming it has one, some don't.
Re: Can't find tank return line L4240
Where is that diagram from? I'm not finding that view on mine. I went through kubotausa com
I then went to parts, then illustrated parts list. Mine is L4240HST-3.
Good point, I was looking at the valve backwards.
About the only option I see would be to cut line 110 in this diagram and put in a compression tee:
Aaron Z
While I don't have exactly what's in your picture (it's an option), I do have the same base. We may be onto something. I don't have line #110 but I have a plug #230 right there. So if that indeed dumps to tank, that would work. I could maybe even purchase that line #110 and then tie into it. The hole is smooth bore and the plug just pushes in. Here are my pictures. Also, not the biggest hole so I'm wondering what it needs to support as far as flow.
   / Can't find tank return line #25
It doesn't, which is the problem.
Aaron Z
Excellent catch. This might work. As the OP said, he doesn't have rear remotes now, so that port is plugged and available.
Doesn't need to be big. Buying that hard line and having a JIC flare brazed/welded to the end would work.
   / Can't find tank return line #26
Take plate #200 off that might be where it is to hook into.
   / Can't find tank return line #27
If you look at Aaron's picture, you will see only two of the three necessary lines go through where plate 200 is. The third line (tank) goes where we are discussing. We know its tank and not P of BY, because when the rear remotes are not installed, a simple o-ringed plug caps it off.
   / Can't find tank return line #28
If you can't find the tank line, add new valve(s) that don't have PB, only tank, and run that into the port that provides pressure to the 3pt. That's how your BH valve stack works and how the dealer added rear remote on my Branson works (and how my BH's valve stack works). As long as the valve is rated for it, it works fine.
(it's confusing to use "tank" both for the low pressure port that really runs to tank when there's a PB port passing on the high pressure, and for the port that combines both flows when there isn't a PB port. But that seems to be the usage. Hopefully it's clear in my posts which I'm talking about)
   / Can't find tank return line #29
I am not sure which transmission you have so adjust accordingly.
There is a steel line on the valve that is the return to tank s/n dependant - Look @ H23300 Hydraulic return line illustration, H280xx is your loader valve. should be a link below:
Kubota L424HSTC (Hydrostatic Transmission / Cabin / 27 - 29) Parts Diagrams
Then look at the loader section & 3rd function kits link below:
Kubota LA854 (FRONT LDR / L424 / 474 / 5:mad: / 524 / 574) Parts Diagrams
item# 04 shows a loader return line that will have an addition fitting on it that you can attach a return hose to.
   / Can't find tank return line #30
The is about all I can find for pics. A couple drawings from Kubota website of what I believe is the right valve. The spot that was curious to me in the drawing was the O ring. Wouldn't need O ring just to bolt on a valve to the side of the case. In thinking maybe that's the passage for the fluid to tank? One of the drawing shows where the pressure relief is. As for my pictures. I got a view of under the seat, a side view, and a shot from up underneath.
Kubota LA854 (FRONT LDR / L424 / 474 / 54 / 524 / 574) Parts Diagrams
If you look at Brian's post 15, last picture, you see a view of the valve from below. There is no return line like your reference shows. The bolt you see is the pressure relief valve, not an unused port either. However, it would be worthwhile for Brian to see whether there is an unused port on the transmission where located on your referenced part list (option 5 drawing).
   / Can't find tank return line #31
Purchasing #110 would be the easiest option, that should just be a thin wall tube with a groove in the end and a tab welded to it for the retaining bolt.
That line should be able to handle the full output of the hydraulic pump as it would need to be able to do that in its intended use.
If you install the Messick's app it lets you see all the Kubota parts diagrams (as well as New Holland, Bush Hog, Ferris, etc), that's where I got that screenshot from.
Yes, that was an option on the older tractors up to 2009 per the parts diagrams, but this tractor is a newer 2010+ HST Plus tractor and it doesn't have that, on the newer tractors the return line goes directly from the back of the valve in the transmission with just an O-ring between to seal it.
Aaron Z
I went to dealer today and while it was not the most helpful experience it did pretty much confirm that part #110 is included in the factory rear remote kit that you can get from Kubota and it is in fact the return line. I'm still wavering on if I'll do my own valve stack or not but I might be starting to lean towards ordering the kits from Kubota and just maxing out what they can provide with 3 remotes. If I did that I could always add my own stack later to provide a couple more and it'd be a lot smaller stack than the 5 I was planning. Way less hoses.
   / Can't find tank return line #33
All it takes is money. Kubota rear remotes are expensive.
On my MX, all three ports are in that plate. If I had a mill, I'd have made an adapter instead of running hoses from the loader valve.
2014 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2014 CATERPILLAR...
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
2016 KOMATSU PC240LC-11 EXCAVATOR (A60429)
2016 KOMATSU...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 CATERPILLAR D3 CRAWLER DOZER (A60429)
2022 CATERPILLAR...
