Can't hook up rear hydraulic line
   / Can't hook up rear hydraulic line #11
You just werent tapping hard enough. It sometimes takes a pretty good hit to open that seat if the pressure is high. My preferred method is to just slam them down on a board with the top of the hose slanted toward my body, then all the oil squishes out away from me. I hooked up hose couplings thousands of times during my time on the farm and never found a hose that couldnt be bled off by hitting the end on a hard object.
Especially frustrating was when you were discing and broke or lost the pull pin. We had emergency disconnects on all our couplings on the tractor so it would automatically uncouple when this happened but it usually meant that the cylinder was fully retracted under max pressure (we carried the wheels completely raised for extra weight on the disc) so one then had to bleed oil off till the wheels hit the ground which could be 1/2 gallon of oil or more depending on the cylinder size. We didnt worry about soil oil contamination back then either and it never seemed to hurt the crops although around the shops it keep the grass down.
A guy told me once back in the 60s they had a big crude oil spill on their land from a ruptured pipeline. They let it set for a few weeks till some of the volatiles evaporated then just turned it under and mixed it thoroughly with the soil. He said the following year, it was like they fertilized the grass, everywhere the oil was it was greener and taller that the rest of the pasture. I cant attest to the truth of this not having seen it though.
   / Can't hook up rear hydraulic line #12
mattlsR4020,
Your other option would be to get QD's that connect under pressure.
Keep in mind that some QD's will connect up to 500 psi, and other QD's, with full pressure.
Thanks for all the tips everybody. My son-in-law is the one who first removed the hydraulic line and I was sure he did something wrong since we couldn't simply plug it back in.
   / Can't hook up rear hydraulic line #14
Something to also think about. I have had the flat face couplers that have done this and I have disconnect the attachment correctly . What happens is the small oring that is on the push in part of the coupler swells or tears from going on and off and will jam the coupler up and the center will not push in to allow you to hook up the attachment.
I have had this happen a few time on my grapple since I take it off and on a lot just wanted to pass on some more possibility for you to look for.
I have had this happen on couplers that were very new but had removed on / off a lot in the first month of use.
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
1996 Moxy MT30S Haul Truck (A55272)
1996 Moxy MT30S...
2270 (A58376)
2270 (A58376)
MASSAGE CHAIR (A58216)
10,000 PSI AIR HYDRAULIC PUMP (A58216)
10,000 PSI AIR...
