OP
Tom_W
- Joined
- May 18, 2003
- Messages
- 115
- Location
- Wallingford, Ct
- Tractor
- Kioti 1914 TLB kl1210 loader and a smc 65a backhoe (same as rhino)
Thanks for all the input. Trailer tires it is.
BIRD is absolutely correct on his analysis. The tires on any trailer used for towing, single or double axle, is subject to "squirming," even in tracking a straight line down the freeway, they are always "hunting a little bit," from side to side creating friction, which is turned to heat! Also, if the tire has aged, and operating at it's max weight/pressure, you maybe subject to a "blow-out!" If you are going to use the trailer only for short distances at low speeds, other type tires maybe okay? I learned the hard way!! Spend the money and be "safe" with trailer tires, and have "peace of mind!"Bird said:Tom, I've been out of the tire business a few years, but I think what I'm about to say still holds true. There are two reasons to use ST (trailer) tires instead of P (car) or LT (light truck tires).
1) There's a slight difference in the chemical composition of the rubber used. The ST tires are built to withstand the ultraviolet rays of the sun a little better and resist "weather cracking".
2) As has been mentioned, with a tandem axle trailer, turning puts a considerable stress on the sidewalls and the ST tires are designed to handle it a little better.
Those were the facts from long ago. What I never actually experimented with myself, but have heard (and believe) is that you DO NOT want to use trailer tires on your car or pickup. But you CAN use car or pickup tires on your trailer. You'll probably have better luck; i.e., longer lasting tires on your trailer if you use the ST tires.
