car trailer how to ?
   / car trailer how to ? #1
9973720wb19
Platinum Member
East Coast
Many
i just got a flatbed car trailer to hall my vintage car; when strapping down do you cross the straps or just pull them straight directly from the car to the downties? ive seen it done both ways,
   / car trailer how to ? #2
I always use chains and binders whether securing a tractor or vehicle. Even though only one front and back is required if under 10K weight I use two in front, two in back. I do not cross them but think crossing them is also acceptable.
   / car trailer how to ? #3
Depends what you are grabbing. I like crossing straps/chains when possible
   / car trailer how to ? #4
Hey there. Chains or 2 inch straps are very exceptable for transporting a car. What are you able to connect to on your car? Frame? If needed j- hooks to fit into the slot of frames work great!! I highly approve straps over the tires as well. Being a wrecker driver in the past I like to cross my chains/ straps as that way you are pulling the vehicle both directions. Always use at least 3 chains or straps or a combination for the load you have provided.
Straps need to be 2 inch IMO and will have a breaking strength of 10,000 pounds/ working load of 3,300. I just bought double j hook straps at menards 25 foot two inch for 10$ !!!! Smart strap brand.
Chains - must use grade 43 or grade 70 in 5/16 or 3/8 or a combination for the two is a very acceptable idea. Binders can be expensive but can be had at tractor supply or menards for a good deal! If connecting chains together you must use only certain connections as "temperary links" void the strength of the chain in the eyes of the dot officer.
   / car trailer how to ? #5
I use 2 in front and 2 in rear. Sometimes crossed sometimes straight, depends on where I am hooking, length of strap etc. What matters most is that they pull against each other to keep the car in place. I usually:
Load car
Connect all straps
Snug all straps
Take car out of gear (and release brake)
Tighten all straps
Put car in gear (and set brake)
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
2006 SHOP BUILT 130 BBL STEEL VACUUM TANK TRAILER (A55745)
2006 SHOP BUILT...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2012 PETERBILT 348 (A55745)
2012 PETERBILT 348...
2000 Ford F-250 Pickup Truck (A55852)
2000 Ford F-250...
