Mowing Care for underside of mower deck
   / Care for underside of mower deck #1
coachgrd
nw PA
Kubota BX1870
Just wondering if all of you could share your strategies for prolonging the life of your mower deck. I've just bought a JD 455 and the previous owner apparently used to spray used engine oil on the underside. Just wondering if I should continue this or one of you have something better. Thanks!
The sun is shining in NW Pa...spring can be far behind a few more snowstorms...
Gary
   / Care for underside of mower deck #2
Gary, I kept a gallon jug with one quart of new motor oil and 3 quarts of diesel, and had a spray rig that put out a very fine mist. That's what I sprayed the bottom of my deck with; kept the grass, dirt, etc. from sticking so bad and made it easy to wash with the garden hose when finished. I used so little of the stuff that a gallon would last 2 or 3 years.
   / Care for underside of mower deck #3
Last year I tried to only cut when it was dry and still ended up with a major cleanup job at the end of the summer. This year I'm going to try something different. I bought a cheapo electric power washer, and I'm going to just drive the tractor up on my oil change ramps and hit it with the powerwasher after every cutting. I figure it'll take me 5-10 minutes tops. I figure that as long as I'm greasing the deck regularly this shouldn't be a problem. ???
Have a good one,
Dave
   / Care for underside of mower deck #4
Gary,
There have been several threads on TBN regarding treatments for the underside of mower decks. All have had mixed results. Any thin coating you spray on the underside of the deck will be quickly removed during mowing. Think of all the bits of grass striking the underside over an over. A thicker coating may change the airflow under the deck or create more drag to the clippings.
Instead of coating your deck, the best advice is to perform periodic cleaning during the mowing season. Removing any grass build up will make the mower perform better as well as last longer. This includes sharpening the blades and lubricating bearings. Don't forget the top side of the deck.
At the end of the mowing season, store the deck in a dry place after cleaning it thoroughly. This might be the time to spray the underside with a light weight oil.
The above is based on 16 years with same mower deck. No underside coatings ever. Typically cleaned once during the mowing season. Tractor is parked outside with no cover. Deck is stored inside during the off season. Deck still has many, many years of life left in it.
Jeff
   / Care for underside of mower deck #5
After every cutting I use the air compressor to blow the top of the deck off. It works really well. About mid-way through the cutting season I will take the deck off to scrape off any clippings from the underside. At the end of the season I will clean it off again.
   / Care for underside of mower deck #6
I posted this in another forum but can't recall where. Back about 1996 I bought a Coleman Powermare gas power washer from Builder's Square, one of the attachments they sold was a angle wand that fitted into the spray gun, it was about 28 inches long with a 90 degree bend at the end that was about 3 inches long. When hooked to a powerful washer it is the best tool for cleaning mower decks and vehicle undersides I ever found.
It's good practice to pull the belt shields off the top of the mower deck now and then to clean the debris out, on my JD the rear wheels tend to throw small pebbles and sand onto the MMM and some of the stuff works down near the belt.
If a lot of grit builds up you will end up replacing that expensive belt more often than you should. /forums/images/graemlins/frown.gif
   / Care for underside of mower deck #7
I know you'll enjoy the JD 455. I just checked the hours on ours this afternoon thinking it might be time for the 50-hour oil change... 1381.
We have never coated or oiled the deck but have no problem with it yet. If the grass is wet or tender and fast-growing it will mat up underneath quicker, and if cutting something like that we clean it with a putty knife or pressure washer after cutting. I have a chain hoist under one of my sheds that I hook to the front of the mower and raise it enough that I can get to the underside of the deck for cleaning or blade changing. Any time you put water on the deck you need to take the inspection plates off the top and be sure you get all the grass out from around the pulleys, belt, etc. as the moisture will setup and cause problems.
   / Care for underside of mower deck #8
I primed and painted the underside of the deck on my murray, and craftsman mowers.. my little push mower too. it is now 15 years old.. starts on the first pull and has no rust.. Use the ruberizing truck bed liner paints.. etc..
I'm not a fan of using diesel, or motor oil ( new or used ) as a deck protectant...probably all those environmental science classes during CE college.. ( Point source pollution is the easiest to control.. and we should.. thats all I'll say.. lest we revive the used motor oil protectant thread that went 'jihad' status a year or so ago...)
Soundguy
   / Care for underside of mower deck #9
i find the best thing is to just keep it clean. scrape it clean of wet grass especially before storing for the winter. cleaning not only protects it but u will get a better cut.
   / Care for underside of mower deck #10
I'll add my vote to the commentors who say it's better to maintain the underside than to coat it. I have tried commercial graphite loaded coatings on my X595 54" mower deck for 2 mowing seasons. At those points where the cuttings tend to flow against the deck, the coating wears off quickly. In other words where you need/want it the most is the first place it disappears from. It isn't so much the grass clippings but the inevitable dirt, sand, twigs, pop-tops, cartridge casings, arrowheads, etc. that you suck up during mowing. Biggest enemy is buildups of wet clippings that change the airflow and promote ruts.
jim
   / Care for underside of mower deck #11
Try to mow only when the grass is dry. This will help a lot.
A lot of the time in wet weather, the grass may be dry but you'll still pick up lots of moisture and have wet cuttings after mowing. I always use the garden hose then. Better if you have decks that you can tilt up or to the side for this, or remove the deck.
Ralph
755INNY:
Do you have any idea what heading the other threads were regarding this same question about mower deck preservation? I did a search and it came up empty. Thanks...
Gary
   / Care for underside of mower deck #13
Try a search on "slip plate" (using AND). I think that's what it was called. Big thread that ran all last summer.
Regards,
Dave
Found the slip plate thread...thanks!
-Gary
   / Care for underside of mower deck #16
Hey Guys ...Well, here's the other side of the story.
/forums/images/graemlins/shocked.gifMower Deck maintenance, what's that? /forums/images/graemlins/shocked.gif
My first deck mowed grass for 22 years before I traded for the present one 15 years ago. I sharpened the blades yearly and clean what ever is still clinging to the deck at that time.
Never applied paint or oil to the bottom of deck,because the grass, dust chaff and dirt will only remove it within minutes anyway. The paint wears away but the deck never rusted beyond surface discoloration and was turned to bright shiny metal after first mowing each year. /forums/images/graemlins/cool.gifI replaced one spindle in 37 years.
/forums/images/graemlins/frown.gifIf you feel better for the activity, then by all means indulge yourself, but it's not necessary. I do wax and dry lube my snow plow to enhance performance & would do the same for my snowblower if I had one /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gifbut I don't believe the underside of a mower deck needs too much after thought. /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gifRayBee
   / Care for underside of mower deck #17
My grandfather would drive his tractor into the edge of his pond (about 4 to 6 inches deep) and run the mower till it was clean. Seemed to work good for him
   / Care for underside of mower deck #18
To clean my mower decks, I "mow" the pine cones which have fallen on the ground. The blades easily shatter them and the resulting pieces act like a sandblaster.
I started doing this three or four years ago and it works wonders. Yeah, it makes one heck of a racket, but I always do it before I sharpen the blades or inspect the deck.
Works for me.
OBTW, personally, I would never ever spray water on a mower deck because the water can get into the spindle bearings and ruin them fast. I suggest using compressed air to clean the top instead of pressurized water. If you must use water to clean, I would suggest just a garden hose. Pressure washers just push water into the bearings and places it shouldnt go....just my thoughts.....(never replaced a bearing ever in 20 yrs with these practices).
dwight
   / Care for underside of mower deck #19
Gary,
I had a 445 also for about 7 years with a 54" deck. I used it for about 2.5 years at my old house mowing about 3 acres. This being my first new tractor, and what I thought would be my last, I scrubed and cleand that deck after every mowing. I was disappointed about the paint wearing off the underside, but I kept it looking nice. I always creased it after washing and never had a problem.
I moved back to Indiana and bought 6.5 acres to build a house on. About 4 acres are mowed, the rest is woods. Again, believing this was to be my tractor for life, and the fact that this was an old farmers field, I bought a bush hog to save the MMM from damage until I had a real yard. I once said something to the local JD dealer about any type of spray that could be used to protect and make the deck easier to clean. They put me onto a product they sold called either Slick Coat or Slick Deck. It looks like a gray primer but contains teflon. They said many farmers would use it to coat equipment and that they had seen it used on mower decks. I tried it and it worked great. It will wear off after a while, but if you choose to not clean it often, it will offer some protection. One can will cover the deck twice.
Fast foward a couple of years. JD offers new X-series and then the 2210. Only down fall I had with the 445 was the lack of 4WD. So, I bought the 2210 with 62" deck. When I traded the 445 in, it looked nearly new after 7 years and 700+ hours.
Really wanting this to be my last tractor purchase, I really wanted this deck to last and be easy to clean. I did some investigation and contacted the local Rhino Linings dealer. He said that they often coated mower decks and that it worked very well. So I decided to try it, worst case it wears off like the paint. So before I ever mowed with the new deck, I striped the underside of blades and brackets and took it to the Rhino dealer. For $95 he coated it with the hard bed liner sprayed smooth instead of this texture. (They also offer a soft bed liner, but you'don't want that one.)
I've used it a 1/2 dozen times and it shows almost no signs of wear of any kind. I have one small spot about 3/8" round that chipped off do to a large #2 stone strike from the new driveway. It doesn't clean up any easier but it is holding up very well. I hope to have a power washer some day and look forward to spraying it out in just a few minutes. I still remove the deck after every mowing (Less than five minutes to do) but I'm not as concerned about geting it cleaned right away.
Other things I've noticed by accident. Mowing wet grass makes clean up easier! The wet grass stays moist and little scraping and the garden hose clean it right up. No scrubbing or heavy scrapping required if you do it just after mowing. Your cut yard may not look as nice do to clumping. I once mowed in a heavy rain because I had to get it done. I hit some standing water in the yard and notice a bunch of grass coming out from under the deck. So when I finished mowing, I went back to that puddle and ran the mower deck in it for a while. When I removed the deck it was almost completely cleaned. Just a few stray pieces of grass! A very long time ago, I had a push mower that had a hose fitting/port in the top of the stamped deck. After mowing, you would hook the hose up and run the mower. Did a nice job.
I highly recommend the Rhino lining or other hard and smooth bed liner material if you want ultimate protection. On used decks they will require sand plasting to bear metal. On brand new decks, they just scuff the factor paint and then coat them.
Good luck. I hope you find this interesting.
John /forums/images/graemlins/cool.gif
   / Care for underside of mower deck #20
After each mowing I tilt the deck up and scrap with a putty knife the underside. My first rider mower is a 1982 model and is still in great shape with no rust. My new tractor (PowereTrac) has a 60 inch deck and I also use the putty knife to clean. I know many use the hose to clean off but in my experience getting water into the take up roller bearings is not a good idea.
PJ
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
iDrive TDS-2010H...
2007 KUBOTA KX121-3 SUPER SERIES EXCAVATOR (A60429)
2007 KUBOTA...
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2025 Kivel Hitch Mini Skid Steer Attachment (A59228)
2025 Kivel Hitch...
