Carryalls
/ Carryalls #21
Gordon,
I like your set-up. I'm thinking of making sides and a back out of 2 x 4s like you did, with cross pieces like the sides of a stake body truck. They could be pinned together at the corners to make it more rigid.
What does the underside of it look like, where the 2 x 4s go down through the floor?
/ Carryalls #22
Gordon,
Welcome to TBN coss.
I used a piece of 2X2X1/4 angle I had to make the edge 3 1/2". Then bolted and lagged 2X4's to make a rim with pockets. It seemed a little clunky as I was making it but it works good and is plenty strong. I cut a piece to short so I mitered the corners as a cover-up to avoid criticism :D
/ Carryalls #23
I use this carryall from Tractor supply: View attachment 345435 View attachment 345436
Just this last week I ordered a hydraulic toplink for it. I drilled holes and put 3 pt pins at the bottom of the uprights. I can lift it high enough so that it can dump now. I plan to side it with some 3/4 plywood I have, and line that with tin flashing. I'll use it as a winter wheelbarrow- horse manure- so that I can leave my snowplow attached to the bucket all winter.
I've had the idea for some time- finally acting on it.
/ Carryalls #24
I also use the TSC carryall. This wood hauler is kept on with two pins that way I can still use the carryall for other chores. The two white scabbards are for my 14" and 18" chainsaws.
/ Carryalls #25
Gordon and GB,
You guys have talent.
Thanks the ideas.
Coss
/ Carryalls #26
I put this together this weekend. The hydraulic top cylinder has an 11" stroke to it- 18" would have been ideal, but I got tired of looking online. I made the difference up with a couple of pieces of flat stock which I drilled out. I'll get some new pins and work out some spacers still. The carryall will have sides and a front of 3/4" plywood. I'll use some inside angle iron for reinforcement probably. I'll use wide tin or aluminum flashing on the wood. This will be for horse manure in the winter, and I want it to slide off easily. Manure will freeze to wood.
View attachment 346363View attachment 346364
Just looking at the pics- I had the thought that if I put a horizontal bar through the two holes above the old side pins, I might be able to attach the top link (minus the brackets) to the horizontal bar. That might give me a better dump angle. I have to look into it.
/ Carryalls #27
That looks like a nifty addition. With winter coming on, local stores might stock those flat, polyethylene snow sliders for kids. I think a couple of those affixed to the carryall deck might let the manure slide off better than aluminum flashing. I bought several a couple of years ago, intending to line the chute of my snowblower...but I developed a bad case of procrastination and haven't gotten around to it yet.
Similar to these: Buy a Turbo Sheet Roll-up Sled for $5.99
Bob
/ Carryalls #28
I built this one last week out of some poplar 2" boards I had. The TSC frame was $129. Coated it with some deck water sealer.
/ Carryalls #29
Here is mine in action. I cut up a few tree tops that came down last winter and hauled them over to be split and stacked for next year or the year after.
/ Carryalls #30
Here's mine. I welded the frame from old bed frame and made the box from PT 2X6's. I built it to carry extra fuel cans, chains, cooler, hot beverages when I'm moving snow. Haven't gotten any snow yet but I moved a blown tire to my other garage/shop to install a tube. Works great for what I need. I use my FEL for moving firewood and such. All together cost me about $50.
2014 John Deere 7230R Tractor (A63111)
2014 John Deere...
2007 PACE AMERICAN 14 T/A DOG HOUSE (A63569)
2007 PACE AMERICAN...
IRET13 Tricycle (A64047)
IRET13 Tricycle...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
