Carter Lumber Pole Barn Plans
   / Carter Lumber Pole Barn Plans #1
jwstewar
Elite Member
South Central Ohio
Kubota L3301
We are kicking around building a pole barn - actually more correctly a pole garage as we currently don't have a garage of any kind. I have an 8X16 shed for tools and holiday decorations and a 12X16 shed w/ the tractor, lots of the kids outside toys and yet more holiday decorations.
I'm thinking about building a 30X48X10 pole building. At this point I've been in touch with Carter Lumber and they have drawn up plans and since I haven't purchased anything yet provided me with a material list. It looks like every thing is there I'm just curious if anyone has had them "design" a pole barn for them and if it turned out OK. BTW, we are going to go w/ Vinyl Siding w/ 7/16" OSB behind it, shingle roof w/ 1/2" OSB under it, and 2 9X7 garage doors on the 30' side for the car & truck and eventually a 9X7 or 9X8 garage door on the side for the tractor and implements.
At this point it is going to be just a dirt floor (short on $ maybe next year), but will eventually be concrete. Should I take the topsoil off prior to starting or just wait until I actually get ready to do the floor.
The materials list has a price of $7097 for "everything" including Quikrete for the poles. Corner posts are 6X6 looks like most of the other posts are 4X6.
Has anybody done one based on a design by Carter? I'm doing this myself or with help from friends and family so this will be a slow time consuming process so I will obvisously have plenty of time if I don't seem something I like in the design that I could change. BTW, depending on the speed and how fast the $ go, this may just be a really large car port that gets enclosed in the future.
Kinda scared haven't ever done this large of project and winter is coming fast - I know it is August, but I'm slow.
   / Carter Lumber Pole Barn Plans #2
Jim: 3 years ago I built my pole barn based on a set of stock plans I got from 84 Lumber. We had me, my Father-in-law and three uncles working on it and we got it up and "under roof" in a week. I finished out the rest of it myself over the next couple of months working weekends.
I say "based" on the stock plans because basically what I did was to take the plans and split them down the middle to add a taller center section for my motor home garage.
You can see the story at My web page
Your project is very do-able. Best of luck.
   / Carter Lumber Pole Barn Plans #3
I was planning to have one priced out tomorrow at three different places-- Carter Lumber and two local places...
I see Bernard Daniels Lumber in Canfield always seems to have cheap prices on their packages in their ads, so I'll go there in person to get one priced the way I want it. They always advertise on page 3 of the Farm and Dairy. They have free delivery within 100 miles of Canfield Ohio.
I was going to go with 30 or 32 feet wide, but got talked out of that-- didn't think about how I was going to get the trusses up there! I've done 24 footers with a helper, but 32 footers would probably be 4 or 5 people, huh? I don't know if I have that many friends!
I wasn't going to get a price from 84 Lumber. Anyone here do a lot of dealing with them? I've always been partial to Carter Lumber. I head there before I go to Home Depot-- the guy behind the counter knows what he's doing, and sometimes the prices are cheaper too! (But I guess that's part of a different thread!)
   / Carter Lumber Pole Barn Plans #4
I just build my own, plans are in my head and go for it,but my brother-in-law just put up a Carter kit this spring.
I don't know exact size (about 24X40) and a couple of his friends helped put it up, it has all steel sides and roof which are much faster to finish.
I don't care much for Carter's lumber like SPF so I buy only #1 yellow pine for about 10-20% more $$ but far superior in strength.
When he bought the building they gave u a Bostich framing nail gun free, this helped out some but a building like yours w/ all wood will save LOTS of time.
The problem w/air guns are the nail cost.
I need carple tunnel surgery again so the nail guns are all I can use.
I buy materials from lots of places and try to get deals then when I've got most of the stuff I go ahead and build.
To save a lot of money check lumber yards for cull trusses (wrong size or cancelled) first then build that size building.
I found 17 44' barn trusses when I was looking for the 30' for my building and bought them for a friend and got them for less than $30 each, close to $100 new.
I built a 30X54X14 eave almost all myself, dad helped a little.
But I have a hoe to set trusses w/ and u can set them by yourself w/ it, the 18' 6x6 posts are a job to stand up by yourself.
I also insulated the walls w/ 1 1/2" foam before putting steel on so it has a little insulation and stops the steel from sweating.
   / Carter Lumber Pole Barn Plans #5
I bought a 34x48x10 steel sided bar from Carter and was very happy with it. For a barn this size you use the 2 page stock plans they sell off the shelf for $3.95. The "design" is really the guy just putting together a list of materials. After building the pole barn I would do it again in a second. My biggest suggestion would be to rent a 25' Rough Terrain scissor lift. It will make putting the trusses up a breaze and will aid in the roof work and trim (especially if you have overhangs).
I'd also ask Carter to get you the glu-lam posts.
</font><font color="blue" class="small">( I'd also ask Carter to get you the glu-lam posts. )</font>
What are these? Never heard of them.
How do these compare cost wise to standard treated 6X6's?
   / Carter Lumber Pole Barn Plans #9
A little more expensive for a 10' building I'm sure, but the poles are the last thing you want to skimp on in a 'pole' building. The Glu-Lam posts should come with a 50 or 60 year in-ground warantee.
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
1272 (A50490)
1272 (A50490)
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
