Case 550 Dozer Front Idler and Track Roller Lubrication
   / Case 550 Dozer Front Idler and Track Roller Lubrication #1
Blueacre2
New Holland TL90A, Case 580 SL, International 574
I just purchased a Case 550 Crawler Dozer with 6 way blade. Machine is in reasonably good operating condition - everything seems to work OK. It came with the Case OEM operator and maintenance manual - I cant find anything in the manual regarding maintenance / lubrication for the front idler and track rollers in the routine maintenance section. I had an older Case 450 dozer and it had grease fittings on the front idler and upper track carrier roller - not sure if they were OEM or if someone added grease fittings. There is no grease fittings so I figure they must be oil bath inside.
The parts manual for the Case 550 shows plugs in the center hub of the front idler and the lower track rollers - I havent looked for them yet. If I can find the plugs should I open them and check oil level - how full should they be ? What grade oil should be used - gear oil or lighter ?
The upper track carrier roller has 3 bolts on the cover plate and one bolt has a copper washer - I assumed the one with the washer is where the oil would be added - is that correct and how full should they be ? I dont want to over fill and blow out the seals. What grade of oil ?
Appreciate any advice
   / Case 550 Dozer Front Idler and Track Roller Lubrication #2
We found a hex head screw in the front idler on the hub facing up and out.
nothing in manuals instructs on Lubrication of this front idler.
still researching
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
Farm Star 4' Off Set Disk (A50515)
Farm Star 4' Off...
2012 Ram 4500 Versalift Bucket Truck (A50323)
2012 Ram 4500...
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
