case 585 timing order
/ case 585 timing order #2
How far did you have it apart? Just the pump?
/ case 585 timing order #4
Give us some info as to what you've done up to now, we weren't there.
Did you have the pump rebuilt?
I'm guessing it wasn't at TDC when you removed the pump.
I believe your machine has the 4 cylinder Cummins is that right?
not to sound rude but I only know what happened after the fact lol yes its a 4 cylinder and it has 1 thru 6 on it plus 4 dot's on the gear if u could just tell me or show me how the timing is id apprisiate it also im doin this (computer) for a friend how is doin the mechanic's work lol
/ case 585 timing order #6
Sorry, after digging a bit it's not the engine I thought it was.
Good luck.
Luck Now 425 (A64126)
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2022 EZ-GO ELITE...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
Rake Master CR-50SG-LD (A64126)
Rake Master...
