Case 8420 baler
/ Case 8420 baler #1
Loie
We have purchased a Case 8420 round baler. the Gathering Wheels, are all worn off. They were rubber fingers, attached to a steel wheel. Does anyone have a good do-it-yourself retrofit? To buy new, they are $305.00 each! We have welding and most metal working capabilities. Also, (forgot to mention) The manual says to get a 60" space between the rear tractor tires pulling the baler. Is this a big deal? Our tractor is in tight, about 40" between the rear wheels.. thanks so much for your opinions...
/ Case 8420 baler #2
Didn't see this first time around.
I got the same machine, same problem with the gathering wheels. I took all the old rubber off and got a 16" steel wheel at the junkyard. Cut the bead areas (2) off the wheel. Got a 16" tire and cut the sidewall in a sawtooth pattern, then fastened the tire section to the steel of the gathering wheel using the bead section of the wheel to hold it in place. Worked ok, I'd give it a C+.
Issues were:
Sidewall of the tire wasn't as stiff as it could be to work well. 2nd pass I'd get the stiffest sidewall tire I could.
16" was ok, but a 17" would probably fit better.
The place I drilled for the bolts to hold it all together happened to be right through the steel of the tire bead - that was nasty drilling.
So at some point I may try this again, taking into account the issue above. But what I got is definitely better than it was. I can post pictures if you like, too bad as I had the baler here at the barn doing some repairs, just put it back in the other barn.
As for rear wheel spacing, the largest problem I have with this baler is the narrow pickup - it's between the baler wheels, not out in front as most are. It takes some real care to make sure the windrows aren't too large. So you're going to want smaller windrows anyway, 40" spacing sounds pretty narrow, but I'm betting it'll work for you if you keep the windrows small.
/ Case 8420 baler
thank you, appreciate your idea. my husband is the one who has to do this, so we'll see how ambition he is. thanks again
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
2019 FORD F-550 SUPER DUTY (A65643)
2019 FORD F-550...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A64553)
Pallet of...
