Comparison Case Maxxfarm 60 Cab or Kioti RX6010C Cab ?
   / Case Maxxfarm 60 Cab or Kioti RX6010C Cab ? #1
MikeFarm
NSW, Australia
Kioti RX6010C
Hi all
I have settled on getting either a Kioti RX6010C or a Case Maxxfarm 60 Cab. Very hard to make that final decision. Is anyone familiar with both and have any advice?
Both of these are 59 HP cab tractors with similar specs and the price for each with 4-in-1 are very close. Both dealers are the same distance away. The Maxxfarm wins with 16x16 gears vs Kioti 12x12 (both shuttle shift) but then I'll be mainly doing slashing so will find a gear in the 12 that the Kioti's has fine. The Kioti main & steering pump is 67 litres/min vs Maxxfarms 52 l/min. The Kioti weight is 2610 kg vs Maxxfarm 2335 kg (1kg is 2.2 lb guys) and the Kioti is wider by about 7 inches. Front tyres the same but Kioti has rear tyres 2 in more diameter than Maxxfarm. The Kioti definitely has the weight advantage.
Cabins of course look a little different between the two. The only problem I have is there is no RX6010 or Maxxfarm 60 close by to actually look at and sit in. I'm going by specs from brochures, talking to the dealers and pictures from the internet :) Lots of pics of the Kioti Cab but not many good detailed ones of the Maxxfarm 60 cab.
Any thoughts that anyone wish to share?
(PS. Have made same post in TractorForum, hope ppl dont mind.)
Hi all
Took a long trip today to have a look at a Maxxfarm 60 Cab. Dealer was very good and took us through all the features and controls. Very nice machine. Looks well made and assembled. Seat is good, controls easy to reach and use. Does not have 540E but does have 750 PTO speed so apparently can set it to this and operate engine at lower revs and still get 540 at the PTO.
Have not yet seen the Kioti RX6010 as there is none near me. Might get to look at a DK551C which is a few hours away. It's close to a RX6010 in appearance. RX only has 540 and 1000 PTO settings.
Mike
Hi all
Looks like no one here has a Case Maxxfarm 60 or Kioti RX6010? I'm going on Sat to look at a DK551 which is the closest there is to a new RX6010 within 1000 km. We'll have to base our decision on what to get on what we like, or not like, about a DK551.
So far the only thing I don't like on the Maxxfarm 60 is the dicky little cup holder. It will hold a foam cup with an inch of coffee in the bottom, but prob not a full can of beer :)
Mike
   / Case Maxxfarm 60 Cab or Kioti RX6010C Cab ? #4
Good luck with deciding which one is right for you! :thumbsup:
Hiya
Thanks. The RX6010 seems scarce on the ground. There isn't one to look at within hundreds of miles of me. So it's hard to decide based on sitting in a Maxxfarm and just looking at pics of Kioti's on the internet.
Mike
   / Case Maxxfarm 60 Cab or Kioti RX6010C Cab ? #6
6010 is nicer than the 551
I wouldn't judge it if you get to see the 551 but not the 6010
BTI
Hi BTI
When I see the 551 I'll be looking at general build quality, paint and fit and assuming the 6010 will be the same. The Kioti blurb says the 6010 has a redesigned bonnet but not very specific about what other changes there are in the cabin. From the pics it looks like the 551 has a similar instrument console but a vinyl seat and the 6010 has a cloth seat. I think the gear and lever arrangement is similar.
Mike
   / Case Maxxfarm 60 Cab or Kioti RX6010C Cab ? #8
Pay attention also to the hydraulic lines. Mine on the Case Farmall 60 are hard lines and attached to the body and the fram of the FEL. Most tractors I have seen have soft lines that drag low and can (and do) get entangled in the brush.
We have loved our Case. It has been steady but needs the tires moved out. The tires can have their position changed so you will be able to widen the stance.
I have a bit of an issue with where the Kioti was built versus where my Case was assembled (US). I do not know if this means anything to anyone, it did to us.
My buddies Branson (same age as our Case) has had three repairs done under warranty. Zero issues with the dealer, they did the repairs with zero hassle. My Case (worked harder, more hours) has had zero issues. Buddy LOVES his Branson.
Hi all
We decided on tractor last week and have just paid a deposit on a Kioti RX6010! Delivery will be probably about end of April.
It was a real toss up as the Case Maxxfarm 60 is quite a nice tractor. We compared it to a Kioti DK55 Cab and had to extrapolate from that to a RX6010 via pics in brochures. Sorta like trying to compare an orange to a Granny Smith apple but only having a Johnathan apple in front of you and trying to guess the different taste.
Controls in the Maxxfarm are well placed, cabin is nice. A few minor things we noticed could have been better. Kioti seemed a little stronger, neater finish on wires. Cabin is more spacious. Oh both tractors had water buildup under trim of bonnet so you get a steam of water when you lift the bonnet :)
Thanks for the advice High Brook Hills. I didn't know about the tires being able to be moved out, neat. Maxxfarms, I read, are assembled in India but the dealer thought it was Korea.
I'll post a few pics when it arrives.
M.
   / Case Maxxfarm 60 Cab or Kioti RX6010C Cab ? #10
Hey MIKEFARM... am having exactly the same issues as you re. Maxxfarm versus Kioti!! If your Kioti arived late April you should have it by now.. What do you think with the tractor delivered.. Any new perspectives on which is the best now that you probably have the Kioti.
My issues have just been complicated by a quote from a dealer that offers a substantial discount off the price for the Maxxfarm 60 .. (about 5K cheaper..)
Regards
Hiya
My Kioti was due to arrive this week but it looks like it will be next week. Had to wait on a shipment to come into Brisbane which I think it did last Tuesday. For me of the two tractors the Maxxfarm 60 was a bit cheaper than the RX6010 by a few thousand but at that price it's more about getting the right tractor than a cheaper price for me. It was still a toss up of one over the other and I'm sure I would have been happy with the Case. Just the Kioti won out as it just "seemed a bit better" for us.
I'll let you know what I think of it next week when I get it :)
Mike
   / Case Maxxfarm 60 Cab or Kioti RX6010C Cab ? #12
I'm pretty interested in the Rx6010 and it seems like you might be the only person on the forum that owns one.
Did you end up taking delivery of your new tractor? If so, congrats :thumbsup:
Could you give us a quick rundown on how you like it and what you like most about it? Any dissapointments?
Of course, if you have any pics, that would just be icing on the cake, especially with a 4 in 1! :D
Hi Piston
Stay tuned :) It just arrived today! I'll try to post some pics later this week.
As for the decision between the Case Maxxfarm 60 and the Kioti RX6010 - the Kioti is the better buy in my opinion. I'm so glad I waited a month for it. Wife and I spent 3 hours with dealer today as he tutored us on its usage. I'll give a more full report later this week as tonight I'm reading the manual for the tractor as the wife doesn't want me to practice on it at night even though it has headlights :)
Mike
   / Case Maxxfarm 60 Cab or Kioti RX6010C Cab ? #14
Hi Piston
Mike
AWESOME! Congrats! :thumbsup:
I'd be especially interested in some pics of the cab if you have any. Thanks for posting!
I can't believe how much lift capacity at the 3 pt hitch that puppy has!
Looking forward to your report. :thumbsup:
:drink:
Hi all
As promised ... pics. My wife and I are really chuffed with it :)
The truck that delivered it had a sliding ramp that made unloading easy.
Spend yesterday getting used to the gears and using the slasher (what we aussies call a bush hog). Got a single tyne ripper and pallet forks with it too.
If you want cabin pics I can do those next week :)
Mike
   / Case Maxxfarm 60 Cab or Kioti RX6010C Cab ? #16
Hi all
Mike
That would be GREAT if you could do that! Also, I'm curious about the transmission? Do you need to press the clutch in every time you shift from forward to reverse? Or from gear to gear? I get confused about all the different designations for transmission names.
What other attachments do you have planned for the tractor? What are your main uses for it aside from slashing?
Does it have a 540E setting?
How do you like the fit and finish of the cab?
I think I'm gonna have to visit a Kioti dealer if you keep posting pictures :laughing:
One of my main reasons for wanting a bigger tractor is for more lift capacity, and especially more lift at the 3 pt hitch for a logging grapple. The RX6010 sure meets those requirements! Nice looking tractor!
Hi Piston
Yes, you need to press the clutch. In Europe they have a RX6010PC which is a PowerShift model which you don't need to press the clutch. That's not available in Australia - we just get the RX6010C. It's a ShuttleShift. It's real easy though, (reduce speed if needed) press the clutch, shift lever from F to R and ease off the clutch.
I was a bit worried how I'd go as I have only ever driven auto cars, not manuals.
However what I found was that in low and medium range when I pressed the clutch the tractor slowed so quickly that I was stopped by the time I then selected the gear I wanted (1,2,3 or 4) and then I released the clutch slowly and it slowly then goes forward again. All very smooth. Whereas with a car you can't afford to really lose speed so you have to change quick and be very coordinated. Have not played much with high range yet.
A single tyne ripper for laying some water pipe, pallet forks for moving general things and moving hay bales.
Nope. Just 540 and 1000. I prob won't use the 1000 at all.
It's excellent. Everything fits nicely. Well laid out. Also came with a small tool kit of some spanners, big shifter and a grease gun for the nipples, the tractor's ones :)
Mike
Hi all
I took some pics of the cabin for you all today. Have posted them to the brand specific section in the new thread below. We can keep this thread for Case-Kioti specific comparison :)
New Kioti RX6010C Cab Tractor
cya
Mike
Rhino DB150 (A57148)
SKID STEER MOUNTING PLATE (A60432)
SKID STEER...
2021 HYUNDAI ROBEX 35Z-9A EXCAVATOR (A60429)
2021 HYUNDAI ROBEX...
LIGHT TOWER (A56857)
UNUSED SDLANCH SDLGC100 ELECTRIC GOLFCART (A60430)
UNUSED SDLANCH...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
