Cat 1 Quick Hitch Bushing Spring Pins - What size?
   / Cat 1 Quick Hitch Bushing Spring Pins - What size? #1
HawkinsHollow
SE TN
Branson 3015R
Long shot, but does anyone know what size the spring/roll pins are for the quick hitch bushings? I bought a set of bushings and I lost the pins. I can order them online but I don't know what size they are. Help!
   / Cat 1 Quick Hitch Bushing Spring Pins - What size? #2
7/16" x 1 3/8" Coiled or spiral pin (not the split pin). JD P/N is: R27999
   / Cat 1 Quick Hitch Bushing Spring Pins - What size? #3
Are you seeking dimensions on the roll pin holding the end of the spring? I can measure mine - I have a Pat's Quick Hitch.
   / Cat 1 Quick Hitch Bushing Spring Pins - What size? #4
The "roll pins" for my generic set of cat 1 bushings is 7/16 ( tight 15/32) by 1-3/8...
This style.....
Dale
Doosan D35S-5 6,900lb Diesel Forklift (A55973)
Doosan D35S-5...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
Terms & Conditions of (Buying through EquipmentDealz Auction) Final (A59213)
Terms & Conditions...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
