cat 345bl
   / cat 345bl #12
   / cat 345bl #13
if you're a novice, stay out of the big machines untill you
get a lot of seat time.
So....how are you supposed to get seat time, then?
I have got only a few dozen hours in a mini-X, and I got pretty good. It also
convinced me to put a hyd thumb on my backhoe. I volunteer my time
free when any friend rents interesting construction machines.
All I can say is start slow and get a lot of practice.
In looking at the CAT site, I see the 315, at 38K# and 122hp, is called a
"small excavator", sandwiched between minis and medium Xs.
   / cat 345bl
If your not experienced in clearing trees with an excavator, you should leave it to a pro. You could wind up a statistic VERY quickly! I would not touch tree clearing with out a hydraulic thumb on the machine either.
is the komatsu pc270lc-7 a good tree clearer?I would clearing with a thumb too.i will also have a forestry package too.i want a machine because i want to use a machine on my own property and after i am more experienced i can do some work for other people.
   / cat 345bl #16
Watch dirtman2007 on youtube. He shows how to clear trees.
   / cat 345bl #17
I ran a 345 when I was a kid working with my dad and grandfather. Very loud turbo! Used lots of fuel but with production comes cost. Yes...to the full throttle comment. I always ran larger equipment as most of the time I was working in quarries, sandpits and large road jobs(fed.). Clearing trees was something I learned to do with an excavator when I was 9 and I'll tell you make sure you have a thumb and a cage around you. I liked knocking trees over with a larger D8/9, having a ground person cut them and a skidder carry them out of the way. Forgot to say I also ran on that same job a evenly sized Hitachi(about 4 yds) and it was much quieter and seemed better on fuel and it was nice as I didn't always have to idle down to talk with someone in a trench.
Then you must consider cost of trucking, repairs etc...can get really pricey. Unless I was really pushed or had lots of space I would stay smaller.
   / cat 345bl #18
A 21 ton machine is all you would need, the 45 ton machines have a hard time finding "side work" unless your into that stuff, big production dirt work. A 200 or 230 hitachi will burn a lot less fuel than a 320 or 330 Cat. I have both. I also have a 450 Deere and honestly man a few hours in the seat is no where near enough time to start clearing bush. I've got thousands of hours in them and still have bumps and bruises on the machines from being in the bush. Get a older D8 or similar with a blade and a brush rake and go to town. And it goes without saying make sure the machine is well guarded. More for you than the machine.
Valvoline Transmission Oil / Power Steering Fluid (A53117)
Valvoline...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2001 Terex 760CM Loader Backhoe (A53117)
2001 Terex 760CM...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
