cat1 to cat2 adapter
/ cat1 to cat2 adapter #1
rustythe4x4
Sask
WHITE 700
I bought an old Ferguson cultivator not realizing my tractor was a cat2, and the cultivator was a cat1 3 point. I didnt want to hack up an antique, so I came up with this from the scrap pile:
/ cat1 to cat2 adapter #2
Looks like it should work.
Let us know if it holds up to the larger tractor pulling it.
/ cat1 to cat2 adapter #3
Man, you should have come here first! For about 5 bucks at TSC or any ag supply they have a sleve type adapter to go over the cat 1 pins to size it up to a cat 2, same goes for the top link. But what you've made looks real nice and should work fine.
/ cat1 to cat2 adapter #4
I just bought the bushings to convert cat 1 to cat 2.
$2 each from TSC yesterday.
Or you can buy cat 2 hitch pins that bolt in
place of the cat 1 hitch pins.
Pooh Bear
I can buy the bushings here for about $1.50 a set (I already have a set) but the arms wont physically fit on the cultivator, the frame is too close.
/ cat1 to cat2 adapter #6
Do they make an adapter to put category 2 implements on a category 1 tractor?
/ cat1 to cat2 adapter #7
Rusty has the correct response I believe. The bushings work to size a cat 1 pin dia. to use a quick hitch. Cat 2 arms are a wider stance and a higher top link. Will a cat 2 rear shrink in adjustment to close the difference to a cat 1 implement. Will the cat 2 components adjust to get the proper performance from a cat 1 implement? What you did looks like it will serve its purpose fine. Just thinking ? My 4420 is cat 1, so I have not encountered this issue. Gene
UNUSED SDLANCH SDLWC WOOD CHIPPER (A60432)
UNUSED SDLANCH...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
PRO SERIES SPRING SWAY BAR HITCH (A60430)
PRO SERIES SPRING...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
2002 Ford E-450 Enclosed Service Van (A59230)
2002 Ford E-450...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
