Catagory 1, catagory 2 three point hitch difference?
   / Catagory 1, catagory 2 three point hitch difference? #11
A 7/8" draw pin is Category 1.
Tractor Supply Company (TSC) and Rural King offer variations. Many draw pin venders on eBay.
Most heavier tractors have Category 1/2 hitches, allowing use of either size implement interchangeably. Not all; most.
MORE: TractorData.com - Three-Point Hitch
   / Catagory 1, catagory 2 three point hitch difference? #12
If a pin is bent, check your stabilizer bar adjustment to make sure there is not excessive 'swing' from your attachment in the turns. I had to cut my bent pin off (with a saws-all) and replaced with a new one from Tractor Supply. Make sure the new pin is snug. I used an air wrench to tighten my new one and then adjusted my stabilizer bars for a tight, straight pull.
   / Catagory 1, catagory 2 three point hitch difference? #13
Jeff - thank you for the .pdf. All the info helps.
Laura
   / Catagory 1, catagory 2 three point hitch difference? #14
Kirk - thank you for the response about your experience. Something to look forward to! I did find a replacement pin today, so will try to replace it then check the stabilizer bar. Laura
   / Catagory 1, catagory 2 three point hitch difference? #15
I had a pin break on one side of the snowblower. With one side of the blower not attached (briefly), the other pin is now bent; I bought a replacement for both pins, but haven't installed the one for the bent pin yet (hey, it isn't snowing anymore, so what's the rush?!).
   / Catagory 1, catagory 2 three point hitch difference? #16
Seems like the kind of thing to keep a couple on hand. Thank you for the reply. Laura.
   / Catagory 1, catagory 2 three point hitch difference? #17
Here's something interesting, my neighbor has a 60 something HP tractor with Cat 1 hitch system.
My 60 hp MF has changable hitch balls. I don't think I've ever used a cat 2 implement.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
3650 (A47477)
3650 (A47477)
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2011 SOUTHWEST  GOOSENECK (A58216)
2011 SOUTHWEST...
