Catching Air
/ Catching Air #1
Southern13
Ford 4000
Ford 4000 3 cyl diesel starts popping after bushoghing for 2 to 3 hours. Air in the lines. Havent found the culprit yet. Ordered a steel hose to replace rubber fuel line. Question, is it possible to bleed the lines while engine is running.
/ Catching Air #2
Yes it is possible to bleed with the engine running. Start closest to the fuel tank with the little bolt head on top center of the fuel filter body, crack and bleed and close, then the banjo on the cylinder closest to the tank, crack and bleed and close, ect until you run out of cylinders. Why do you think you get air in the lines?
2016 FREIGHTLINER 125 DAYCAB ROAD TRACTOR (A65054)
2016 FREIGHTLINER...
2000 Mack DM690S T/A 2,000 Gallon Water Truck (A66736)
2000 Mack DM690S...
2011 Cub Cadet 42in Riding Lawn Mower (A66738)
2011 Cub Cadet...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
2016 Peterbilt 348 26ft. Rollback Truck (A66736)
2016 Peterbilt 348...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
