Category 0 Implements
/ Category 0 Implements #1
superfly611
hi all! i am hoping to pick up a honda rt5000 and was wondering where i can find cat 0 implements. i would love to find a small flail mower and various stuff. all i can find is single bottom plow, 2 gang cutharrow (1row), scoops and booms. boring stuff. i want a cutharrow with a 4 gang tandem setup and other interesting attachments. any recommendations?
/ Category 0 Implements #2
It would help to know where you are. If I tell you of a place in WA and you are in FL, it won't help much.
Bruce
/ Category 0 Implements #3
You need close to forty pounds of total harrow weight bearing on each notched disc in order to cut through vegetation.
I do not think you can find a disc harrow with even twenty pounds bearing on each notched disc in Category 0…....but I have been wrong once or twice.
Tractor Supply Company (TSC) sells dropped clevis sub-compact tractor implements in 'Countyline'. Countyline sub-compact implements are painted RED. These may be Cat 1, but you can add TSC conversion bushings to Cat 0 draw pins, so that Cat 1 implements will lift.
There is consensus on T-B-N that a TANDEM Disc Harrow requires five tractor horsepower per foot of width + 4-WD to pull. That is why you only find SINGLE-ROW Disc Harrow offered for the RT-5000
In my opinion you have bloated expectations for eleven horsepower (new) and two wheel drive.
Tractordata Honda RT5000:
http://www.tractordata.com/lawn-tractors/000/6/6/666-honda-rt5000.html
i heard these little rt5000 are crazy strong! im only looking at it as a toy. you think i should shy away from getting it? not sure what im gonna do with it et but we'll see. waiting for more advice. i was mainly interested with the 4x4 aws and its compact size. just thinking of it for tinkering.
/ Category 0 Implements #5
Spend your money as you like.
However, the expectations expressed in your opening post, are likely to be totally disappointed.
Buy a tractor with at least twenty horsepower, a Category 1 three point hitch and four wheel drive.
A front end loader (FEL) is the most useful tractor accessory.
There are a bizzilion well maintained, used, diesel 'Cat 1' tractors available at this time of the year.
KINDLY FILL IN YOUR T-B-N PROFILE.
/ Category 0 Implements #6
The RT5000 was last made in 1989, so if you get the last one off the assembly line it is twenty-four years old.
If it had eleven horsepower new, how much power does it have in 2013? Eight?
your right. i was looking at it as a unique item. i decided to pass it up. to many projects now. i'll save it for other projects. thanks for the advice.
/ Category 0 Implements #8
Cat 0 stuff is rare and expensive. That is what my JD garden tractors are.
You can get all kinds of stuff, but you usually need to pay more than cat 1, and find it used as current manufactuers of attachments dont do much/any cat 0.
/ Category 0 Implements #10
I dont know what your honda makes for power, but here is what they have listed for the moldboard plow:
Required HP 40
thanks about the recommendation for northern tools. ive decided not to get it. it would've been more of a hobby thing i'd be doing with it. it would be a novelty probably so i'll save it for a different project.
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
2021 Scag Turf Tiger II 52in Zero Turn Commercial Mower (A64194)
2021 Scag Turf...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2011 GMC Acadia SUV (A64557)
2011 GMC Acadia...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
