CADplans
Elite Member
I have heard of limited CAT I, but,, otherwise, I thought CAT I was CAT I.
Not so,,
I purchased a Woods RD72 mower last weekend,, to use behind my CAT I equipped JD 4105.
I unloaded the mower, backed up the 4105, checked the PTO length,,, and then connected the mower to the tractor.
When I lifted the mower, this is what I found when I rotated the gauge wheels.
The previous owner told me one of the gauge wheels had been bent,, I think this is what caused it.
The Woods manual says if this interference occurs,, move the rear tires to eliminate the interference.
That ain't happening,,,
I decided I would move the mower back with a couple bracket extensions.
That seemed it would be easy enough,, NOT!!
I fabricated a couple extensions,, 3/4X4X10 inches.
I drilled 2 hole 6 inches apart,,
Then I bolted the extensions on,,,
The first time I lifted the mower with the extensions,, I think the gauge wheel clearance was even worse!!
Then,, I rotated the extension,, and lifted again,, better.
I rotated the extensions some more,, even better.
Finally, I found what seemed like the sweet spot.
With the mower all the way up, I have about 3 inches of clearance between the tractor tire and gauge wheel.
The mower seems to be located in a nice spot for mowing,,,
but,, I will have to wait for the Harvey rain to pass before I can give it a test.
I guess I have learned,, CAT I is not always CAT I.
LOL!!
Not so,,
LOL!!
