Caution: Tiller can be dangerous going down hill
   / Caution: Tiller can be dangerous going down hill #11
Bet a reverse rotation tiller would've worked out well going down that hill. :)
   / Caution: Tiller can be dangerous going down hill #12
Down- yes :); but what about tilling up that hill with that heavy tiller and relatively light tractor :eek:? Jay
   / Caution: Tiller can be dangerous going down hill #13
It would have tilled the snot out of the bottom of the hill!!
   / Caution: Tiller can be dangerous going down hill #14
hz293 said:
I have one area that is about 3/4 acre, about 75 ft wide and is downhill. (Or uphill. Depends on how you look at it.) At the bottom of the hill is a drop off. I don't know grades but if you tried to go sideways, over you'd go. I have a Kubota B7510hst and an Agric tiller which is quite heavy. With the tiller on, starting up the hill, even with a full bucket the front wheels will lift off the ground. So of course the only way to till is going downhill, I thought.
It did fine untill I was near the bottom on the first pass and the tiller hit some loose dirt and started pushing me . I hit the brakes but the tractor wouldn't stop. It took me a couple of seconds to realize that the tiller was what was pushing me along quite fast, downhill toward the drop off. Then it took me a couple seconds more to figure out that I should push the clutch in to stop the PTO. It was pucker city but I got it stopped just in time.
I just wanted to relate this incident here on the forum to alert others that going downhill with a tiller can be dangerous and to be prepared in case it starts pushing you. This was the first time I tried to till this part of my land. It will also be my last.
Harris
I have an Agric CR-45 that weighs 400lbs that I run behind a 2WD 15hp Mitsubishi, I only have 179lbs of ft. end weight, it does real well but I have not tilled down hill.... only sideways.
You must have a much bigger Agric tiller for it to be heavy for the B7510.
Good thing you figured out what to do before it was too late:)
Rooster Weathervane (A55853)
Rooster...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2018 MGB 2500HP QUINTUPLEX FRAC PUMP (A55745)
2018 MGB 2500HP...
2003 TRANSCRAFT 45FT. FLATBED TRAILER (A55745)
2003 TRANSCRAFT...
2011 GAYLEAN 130 BBL VACUUM TRAILER (A55745)
2011 GAYLEAN 130...
2017 Ford F350 (A55973)
2017 Ford F350...
