cav pump ford 3600
   / cav pump ford 3600 #1
ford36000
Athlone
ford 3600 ford 2910
Hi I have a ford 3600 for the last few years always gave me a bit of trouble with the injector pump, would have to tap it to get tractor started but now it wont start at all after been lying up for six mounts ,I can get fuel to the bleeding screw but not to the injectors, now I have a change to get a recondition one of a ford 4600 was never fitted, the only concern I have is the dpa numbers are not exact , on my pump the number is 3233f380, on the pump I am getting it is 3233f390 will this fit, or will I have to get it timed/adjusted any help on this would be great , :confused:
   / cav pump ford 3600 #2
Welcome to TBN :)
I moved your thread to the New Holland/Ford Owning & Operating Forum.
   / cav pump ford 3600 #3
the pressure is set a little bit higher but it will work the timing is the same and it will fit
sorry new to this site , will know where to post in future ,, and thanks
thanks for replying, have it fitted now I have a new problem I am getting diesel, to pump, bleed screw nice steady flow seems like I have been turning engine over for about a hour, on and off of course , able to get diesel to injectors but with air, can not seem to bleed it out, will try and get some one to give me a tow later see how that goes ,
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
1988 BASSTRACKER 20' PONTOON BOAT (A51247)
1988 BASSTRACKER...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
2015 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2015 FREIGHTLINER...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
