CBN-E314 8.8 GPM to try and conver princess auto stock pump SKU;8375404
   / CBN-E314 8.8 GPM to try and conver princess auto stock pump SKU;8375404
Good day Bob, I not sure will check but the problem at that point is the main front end plate wont line up with the mounting holes for sure one could get a custom front end mounting plate but that does not make it cost effective.
   / CBN-E314 8.8 GPM to try and conver princess auto stock pump SKU;8375404 #12
Hello Tommy, I did get a pump from your store "thank you" sent to Ottawa Ontario but the internal tolerance is to weak and blow the gasket but I have to say that is all my fault because I increase the spool pressure to play between 2200 and 2400 psi to get a better curl up lift was missing that extra 200 psi to work it the way I want it. the pump you sent was a original CBN E314 thank you for your reply.
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2016 Ford F-550 Enclosed Service Truck (A51692)
2016 Ford F-550...
