CCM T-N-T, Finally
   / CCM T-N-T, Finally #21
If you don't need the DPOCV's on the top or side links, you might as well buy the cylinders and hose yourself.
I'm sure it would be a lot cheaper and easy to do. Not only that, those cylinders from CCM have British parallel pipe fittings for their ports so they can use those banjo bolts and fittings needed for their check valves. You can buy cylinders yourself with either American NPT or ORB (SAE) fittings (just look at the cyl specs) which will make it a lot easier to plumb.
I just installed an entire top and tilt with a new 4 spool Prince SV valve on my wife's Jinma 284.
Bought the valve and cylinders at Burden Sales Surplus Center - Hydraulic Cylinders Pumps Motors.
I made all the hose myself using re-usable hose ends for a perfect fit.
Bought that stuff at Discount Hydraulics.
You can go to this thread and look for the top and tilt project in it. I'll be updating that thread later tonight with finished results from all the mods I did. I have to re-size and upload a bunch of photos first.
Here is the thread: New Mods to Loretta's 284 Jinma
Rob-
   / CCM T-N-T, Finally #22
Thanks Rob- The one thing I had not found yet was a source for a side link cylinder all ready to mount. Your metal fabrications skills exceed mine by just a touch... :)
I did get out and play with the blade in the mud a little today- was able to smooth out a section of my road that was getting bad on the corner, and only had to adjust the tilt 3-4 times. A pain, but not yet worth $1000 to me.
I'll still do it, but will take my time putting together the pieces this summer I suspect.
   / CCM T-N-T, Finally #24
I suppose I'll call them next week- I have a low tolerance for companies that have email addresses, but refuse to keep up with them though.
I surf and shop at night, and prefer to get quotes by email as it cuts down on the mistakes on both ends.
Same here, I'm in Iraq and emailed them 2 or 3 times about a HTL, never got a response so I said to **** with it.
Well, it's been a little rocky and I'm not done yet but I am getting close! Getting hoses proved to be a little harder than I imagined and a heck of lot more expensive than I thought.
I ended up having to cut the clevis on the rod end of the tilt cylinder off and make a new one. I got it welded up today. The clevis on the barrell end had to have bushings put into it but that was pretty simple, TSC had some sitting on the shelves.
The hard part is finding a new pin to replace the one that attached the old side link to the lift arms. The new set up is considerably wider so my existing pin is too short. What I discovered is that Kioti apparently uses a non-standard swivel eye on the lift arms. It measures .705" so a 3/4" pin will not fit in there. A 5/8" pin is too small and would cause long term issues.
So I'm now trying to track down anything I can make a pin out of. I can have something turned but I don't have access to a lathe like I used to so it's more difficult to get odd-ball sized stuff like this made up.
Hopefully I'll have some photos of the final install later this week.
   / CCM T-N-T, Finally #26
Could it be metric? Check an industrial supply place like Grainger or McMaster Carr.
Ken
I'm willing to bet it is metric (19mm). I forgot to mentiom that. I'll look around, thanks for the tip. (McMaster didn't have anything)
   / CCM T-N-T, Finally #28
First, see if the pins that used to be on the bottom will fit the top. My bottom pins were longer than the top ones. Then get yourself some 11/16" drill rod at the hardware store. That is not too small and will work nicely. You can cut to length and drill some holes for small lynch pins or grind a circular groove and use retainer clips.
Well Rob, I took your advice. The lower pins weren't long enough so I ordered some 11/16 drill rod from Fastenal. No one around here had it that I could find. It came in today. I didn't even really look at it when I picked it up, just threw it in the car and headed home ( I work about an hour from home). Pulled it out and went to insert into the eye and... yep, wrong size.
Freaking .500" rod. It's labeled as 11/16" and even has the Fastenal part number for 11/16 taped to it!
So, try this again, on Friday.
One day, I swear, I'll have a working set up. I swear!
   / CCM T-N-T, Finally #30
Oh man, don't you hate it when that happens?
I find myself doing that all the time ... find out when I get home it's the wrong friggen size.
2020 Ram ProMaster 1500 Van, VIN # 3C6TRVAG5LE100108 (A51572)
2020 Ram ProMaster...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
FRONTIER AH11G LOT NUMBER 112 (A53084)
FRONTIER AH11G LOT...
Sears/Craftsman Shredder (A51573)
Sears/Craftsman...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
